06-05-2017 07:38 AM
We have stack of two SG500X-24 and five SG500-52:
Current stack mode is : advanced-hybrid
Topology is Ring
Stack image auto synchronization is enabled
Unit Model Name MAC Address Software Master Status
1 SG500X-24 e0:d1:73:f4:1c:f5 1.4.7.6 Enabled master
2 SG500X-24 e0:d1:73:f4:1d:86 1.4.7.6 Enabled backup
3 SG500-52 c4:72:95:30:b0:e7 1.4.7.6 Disabled slave
4 SG500-52 c4:72:95:41:2e:7a 1.4.7.6 Disabled slave
5 SG500-52 c4:72:95:32:b4:88 1.4.7.6 Disabled slave
6 SG500-52 c4:72:95:41:2e:45 1.4.7.6 Disabled slave
7 SG500-52 00:8e:73:d4:22:14 1.4.7.6 Disabled slave
All switches connected together using SFP-H10GB-CU1M or SFP-H10GB-CU5M:
Unit Port Connected Port Administrative Operational
No. Unit Status Speed Speed
1 S1-5G 3 active 5G 5G
S2-5G 2 active 5G 5G
2 S1-5G 1 active 5G 5G
S2-5G 7 active 5G 5G
3 S3 1 active 5G 5G
S4 4 active 5G 5G
4 S3 3 active 5G 5G
S4 5 active 5G 5G
5 S3 4 active 5G 5G
S4 6 active 5G 5G
6 S3 5 active 5G 5G
S4 7 active 5G 5G
7 S3 6 active 5G 5G
S4 2 active 5G 5G
After Reboot Configuration:
Current New Stack Mode Stack Ports Speed
Unit No. Unit No.
1 1 advanced-hybrid S1-S2-5G 5G
2 2 advanced-hybrid S1-S2-5G 5G
3 3 advanced-hybrid S3-S4 5G
4 4 advanced-hybrid S3-S4 5G
5 5 advanced-hybrid S3-S4 5G
6 6 advanced-hybrid S3-S4 5G
7 7 advanced-hybrid S3-S4 5G
SW version and boot version is latest:
Unit SW version Boot version HW version
1 1.4.7.6 1.4.0.02 V04
2 1.4.7.6 1.4.0.02 V04
3 1.4.7.6 1.4.0.02 V04
4 1.4.7.6 1.4.0.02 V04
5 1.4.7.6 1.4.0.02 V04
6 1.4.7.6 1.4.0.02 V04
7 1.4.7.6 1.4.0.02 V04
Every hour or two stack port S3 and stack port S4 goes down and up (only between SG500-52 switches):
Replacing all the cisco stack cables did not help.
06-09-2017 03:24 AM
My name is Rozana and i am an engineer from the SMB team.
I see that you are facing stack issues in your ring topology.
Could you please test if you will have the same issue using a chain topology?
Also i think it would be best if you call our support line, so we can create a case and troubleshoot your issue.
06-09-2017 05:54 AM
Changing topology to chain did not resolved the issue.
Also I tried to change stack mode to basic-hybrid, but it did not help to.
06-09-2017 06:01 AM
Hello Again,
Then i think we should create a support ticket and view the show tech outputs and logs.
Also you mentioned you changed the Cisco Stack cables - what do you use?
