06-04-2014 03:15 AM
we have one problem. We have two SG500X-24 Switches and we want to connect 4 x 10GBit/s and use also the stacking feature(with the other two ports)
But when we configure the switch with one of the two stacking modi in the webinterface, Port 3 and 4 aren't activated anymore? Is that a firmware limitation, or it isnt possible to use stacking and 4 port 10Gbit connection.
thank you and best regards,
Tarik
Solved! Go to Solution.
06-05-2014 09:37 AM
The two ports are shared. It's either one or the other. You should be able to stack over the 10GbE links between the units however.
06-05-2014 09:37 AM
