SG500X - stacking port and 10GE Uplink
HNS
I am using a SG500x in native stacking mode, utilizing the S1/S2-5G ports for stack. I use XG1/XG2 ports as 10Gb uplinks but i'm not able to use XG3/XG4 ports.
How can I reconfigure XG3/XG4 as network ports to have 4 SFP port per switch available without losing stacking mode ?
There is what i found in differents manuals (+ link for sources)
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/Sx500/administration_guide/500_Series_Admin_Guide.pdf
Page 74 :
SG500X/ESW2-550X Devices —
S1-S2-10G are stack ports by default.
You can manually reconfigure S1-S2-10G and S1-S2-5G as network ports or stack ports.
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/Sx500/quick_start/en/500_Series_QSG_En.pdf
Page 14 :
It seems I am stuck with this stacking option :
Stacking Option Two:
• Ports XG3/S1 and XG4/S2 are not available
• Port S1, S2 and 5G are configured as stack ports
     – Speed — 1G, 5G, 1G/5G-auto
• Ports XG1 and XG2 are available as standard network ports
     – Speed — 1G or 10G
When I go CLI there is no status for XG3/XG4, but only link state "not present"
switch#show interfaces status XG 1/1/1
                                             Flow Link          Back   Mdix
Port     Type         Duplex  Speed Neg      ctrl State       Pressure Mode
te1/1/1  10G-Fiber    Full    10000 Disabled Off  Up          Disabled Off
switch#show interfaces status XG 1/1/2
                                             Flow Link          Back   Mdix
te1/1/2  10G-Fiber    Full    10000 Disabled Off  Up          Disabled Off
switch#show interfaces status XG 1/1/3
                                             Flow Link          Back   Mdix
te1/1/3       --        --      --     --     --  Not Present    --     --
switch#show interfaces status XG 1/1/4
                                             Flow Link          Back   Mdix
te1/1/4       --        --      --     --     --  Not Present    --     --
switch#
switch#
switch#show interfaces status XG 2/1/1
                                             Flow Link          Back   Mdix
te2/1/1  10G-Fiber    Full    10000 Disabled Off  Up          Disabled Off
switch#show interfaces status XG 2/1/2
                                             Flow Link          Back   Mdix
te2/1/2  10G-Fiber    Full    10000 Disabled Off  Up          Disabled Off
switch#show interfaces status XG 2/1/3
                                             Flow Link          Back   Mdix
te2/1/3       --        --      --     --     --  Not Present    --     --
switch#show interfaces status XG 2/1/4
                                             Flow Link          Back   Mdix
te2/1/4       --        --      --     --     --  Not Present    --     --
There is result of show stack for more details about my setup.
switch#show stack
Current stack mode is  : native
Topology is Chain
Stack image auto synchronization is enabled
Unit Model Name     MAC Address       Software  Master   Status
1    SG500X-24      XXXXXXXXXXXXX 1.4.8.6   Enabled  master
2    SG500X-24      XXXXXXXXXXXXX 1.4.8.6   Enabled  backup
Unit Port  Connected  Port    Administrative Operational
No.        Unit       Status  Speed          Speed
1    S1-5G 2         active   Auto           5G
     S2-5G 2         active   Auto           5G
2    S1-5G 1         active   Auto           5G
     S2-5G 1         active   Auto           5G
After Reboot Configuration:
Current  New      Stack Mode         Stack Ports                        Speed
Unit No. Unit No.
1        Auto     native             S1-S2-5G                           Auto
2        Auto     native             S1-S2-5G                           Auto
Thanks anyone for help ;)
HNS,
0 Replies 0
