SG200-08 firmware upgrade
Hi, I want to upgrade my FW to the latest 1.0.8.3 - but using the dialog Upgrade device software -> via HTTP -> select Source file name (SG200-08x_FW_1.0.8.3.stk) and apply I'm always getting an OK dialog? And it never starts processing...any ideas?
THX
davemeyer2
Same problem as well.
I had the same problem, I solved it by using Internet Explorer, (not Edge, just IE)
Ppatrikk
edit: sorry for dublicate
