SG550XG Layer (3) & 2960x (Layer2) Vlan/Switch communication
Tim Lehmann
Hello
i am a little bit rusty/newbie in Cisco Networking. Maybe some of u guys could help me out?
i got some problem to setup our new network enviroment with a SG550XG 24F (Layer 3 ) and several 2960X (Layer 2) Switch.
We have several VLANs but somehow i can't communicate btw the Switches (Ping btw Switchen & VLANs).
i attached the config so you could have  look what is done so far.
ty in advance
5 Replies 5
nayef salem
i had a quick look at the config
first of all
- are all these VLANs created in layer 3 switch exist in Layer 2 switch either by vtp or manually.
-  i notices layer 2 switch has ip routing  command activated , you need to remove it
no ip routing
- in layer 2 switch , which port is the uplink and also it has to be made into trunk as a first step for pings to be success
provide in layer 2 switches
show vlan
show interface trunk
sho vtp status
Hi nayef salem
Thank your for ur answer.
yeah i did creat all the vlan on both switches.
and i made ur suggested change with the no ip routing and attached the results from
- show vlan
- show interface trunkk
-show vtp
ty in advance
Hi Tim
can you do sho cdp neighbor
show running interface g1/0/25 of layer 2 and also same for  the uplink  interface switch L3
which port in L3 switch is the uplink between L2 and L3 switch?
also i notice in layer 2 switch native vlan is 1 and  10.0.0.0/24 and it's removed from the trunk of all interfaces in L3 switch?! when you connect between these switches , what is the color of the uplink , amber or green or blinking amber ?
okay i reset the SG550XG and  made the configuration new from scratch.. it works so far pretty well! but there are still some issues..
- Layer 3 Switch can ping everything in VLAN1& 60
- Host (Port 18) on Layer 3 can ping everything in VLAN1 & 60
- Layer 2 Switch can ping everything in VLAN1 but can't ping host on Layer 3
- Host on (Port 2) can ping everything in VLAN1 & 60
any suggestions? i tought i could be FW reason but i can ping from l2 host to l3 host..
i attached the new config files
ty in advance
my dear
i don't know what is your purpose exactly as things are mixing up but you are almost there
when you say
does it mean in the same switch or even hosts connected to layer2?
same question above
same question above + it can't ping hosts in layer 3 switch because you are not allowing vlan 1 or 60 in layer 3 switch
same question (does it mean in the same switch or even hosts connected to layer2?)
one question keeps hitting me , in the uplink interface btw the 2 switch (L3,L2) , why do you allow it vlan 1,60(L2 sw) and remove it in L3 sw ??!!!
First things First
you didn't send show cdp neighbor
1- what are the ports connecting layer 3 to layer 2 switch
if am correct it's like this
                  layer 3 sw                                     layer 2 switch
                 1/0/12                  ---->                       1/0/25
then under layer 3 switch inter the following commands
interface TengigabitEthernet1/0/12
 switchport mode trunk
 switchport trunk allowed vlan add 1-83
under layer 2 switch inter the following command
interface GigabitEthernet1/0/25
 switchport trunk allowed vlan 1-83
 switchport nonegotiate
2- remove
ip route 10.0.60.0 /24 10.0.60.65 metric 1
from L3 switch as this subnet is directly connect SVI vlan to the switch
let me know
also since you resetted the SG550 , make sure it's in L3 mode in GUI under administration so it will route between the vlans
cheers
