SGE2010 and IPv6 configuration
STux28320
Dear sirs,
I own a /48 ipv6 address block , and i'd like to cut it in /64 blocks with a SGE2010 switch .
Layer 3 and IPv4 configuration works well : IP configuration on vlans and IP routing between vlans.
MachineA (172.18.10.200)    <====> (172.18.10.253/24) switch (172.18.255.1/24)   <=====> MachineB (172.18.255.100)
I'd like to do the same configuration in ipv6 : but i experience problems :
When i want to add an ipv6 interface, it doesn't add it, but replaces the already defined ipv6 interface.
I first thought of a problem with web administration interface , so i tried to define a configuration file like this :
vlan database
vlan 2,255
default-vlan vlan 10
exit
interface ethernet 1/g6
switchport access vlan 2
exit
interface ethernet 1/g47
switchport access vlan 255
exit
interface vlan 2
name Wan
ip address 172.18.1.253 255.255.255.0
ipv6 enable
ipv6 nd dad attempts 0
ipv6 address 2001:7a8:5a90:1::60/64
exit
interface vlan 255
name Admin
ip address 172.18.255.1 255.255.255.0
ipv6 enable
ipv6 address 2001:7a8:5a90:255::1/64
exit
interface vlan 10
ip address 172.18.10.253 255.255.254.0
ipv6 enable
ipv6 address 2001:7a8:5a90:1000::2/64
exit
hostname sw-48-1g
clock timezone 2
And i uploaded it through the web interface , replacing the startup-config.
After rebooting the device : only the vlan2 ipv6 configuration is used ... all other vlans only respond in IPv4 .
Did I made something wrong ?
Regards.
0 Replies 0
