Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2917 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4497 Views
  • 1 replies
  • 16 Helpful votes
HelloI need a bit help upgrading a SRW2024 to latest firmware.I started by upgrading to v.1.2.2, but the switch just started rebooting all the time, I flashed back to 1.0.0.86 via console xmodem.On Cisco FAQ theres a guide how to upgrade the SRW2024....
plnielsen by Level 1
  • 2390 Views
  • 6 replies
Hello,just to put this out there, I am a noob to the world of Cisco, just got my CCNA, and am now working as an intern.Can you set esw 520 switches to use auto QoS?  We are putting the 520's into an environment of more configurable catalyst switches,...
Dear sirs,I own a /48 ipv6 address block , and i'd like to cut it in /64 blocks with a SGE2010 switch .Layer 3 and IPv4 configuration works well : IP configuration on vlans and IP routing between vlans.MachineA (172.18.10.200)    <====> (172.18.10.25...
STux28320 by Level 1
  • 1146 Views
  • 0 replies
Hello,I have a serious problem when copy great files via network. Before switched were changed by this model, all works perfectly, but now network is blocked when traffic is high, and ping isn't continued.Installation is 2  SGE2010-G5 in stack mode. ...
Hi Everyone,I have a Cisco SFE2000 that has a web admin interface which I use to configure. This is the structure of my current network:        ...
sharpcall by Level 1
  • 4243 Views
  • 2 replies
Hello,I have SRW2048 worked for a week. Yesterday it starts to drop packets and giving long pings.There are problems to connect to web GUI as well. Ones it answered and switch showed 100% CPU utilisation.After disconnecting every cable exept same pro...
ivarsroga by Level 4
  • 1386 Views
  • 5 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
