ā01-29-2015 11:31 PM
Is there a way to show interface overruns? I wish they'd use the same syntax as on their enterprise switches.
ā02-01-2015 03:53 PM
Hello Patrick
the most detailed statistics output on SGX00 switches what I found is "show interfaces counters interfaceName ifNum". But neither of counters mentioned here are related to overruns. Hope you found this as well. I am afraid that there is no else command implemented which provides statistics about overruns.
If your switch is still under warranty then I would suggest you to open case to Cisco SMB support and ask for this feature.
ā02-02-2015 12:05 PM
There may be an expanded counter using SNMP. In most cases ETHERLIKE-MIB contains most counter types. I know for IOS OLD-CISCO-INTERFACES-MIB certainly contains overrun counters but I do not believe most of this has been carried over in to the MIBS on the SMB platforms.
ā02-02-2015 03:59 PM
I have checked SNMP ifTable, but situation is same - overruns are not included. Only following are present:
IF-MIB::ifAdminStatus
IF-MIB::ifDescr
IF-MIB::ifIndex
IF-MIB::ifInDiscards
IF-MIB::ifInErrors
IF-MIB::ifInNUcastPkts
IF-MIB::ifInOctets
IF-MIB::ifInUcastPkts
IF-MIB::ifInUnknownProtos
IF-MIB::ifLastChange
IF-MIB::ifMtu
IF-MIB::ifOperStatus
IF-MIB::ifOutDiscards
IF-MIB::ifOutErrors
IF-MIB::ifOutNUcastPkts
IF-MIB::ifOutOctets
IF-MIB::ifOutUcastPkts
IF-MIB::ifPhysAddress
IF-MIB::ifSpecific
IF-MIB::ifSpeed
IF-MIB::ifType
