12-18-2018 10:55 AM
I am trying to share Internet with my flat but I don't want the people in the flat to have access to my internal network. I was told the SG200-08 could do this - how do I set it up? My idea was to have Management with VLAN ID 1 on ports 1-2, Internet on port#3 with VLAN ID 100, my part of the house on ports 4-7 with VLAN ID 200 and the flat on port 8 with VLAN ID 300. To assign Internet to ports 4-8, I gave port 3-7 VLAN 100+200 and port 8 VLAN 100+300. All ports 4-8 then got Internet connection but they can also ping each other, which I did not want to. So apparently this is wrong - any ideas how to easy set this up?
12-21-2018 02:47 AM
The SG200-08 is only L2 device, so it will depend on your router also - what is the brand/model?
Cheers,
Mike
12-21-2018 01:24 PM
12-24-2018 12:27 AM
I didn't see any VLAN support for RT-AC68U out of the box:
https://www.asus.com/Networking/RTAC68U/specifications/
Anyway, you need to have capability to create several networks in your router and assign to particular port the corresponding VLAN. Then devices connected to this port will get the corresponding IP.
For example you can set LAN1 to be member of VLAN 1 (DHCP pool - network 192.168.1.0 mask 255.255.255.128) and the device will get lets say first address after router - 192.168.1.2 with mask 255.255.255.128, default gateway 192.168.1.1 and broadcast 192.168.1.127.
But LAN2 is member of of VLAN 2 (DHCP pool - network 192.168.1.128 mask 255.255.255.128) and the device will get lets say first address after router - 192.168.1.130 with mask 255.255.255.128, default gateway 192.168.1.129 and broadcast 192.168.1.255.
Both networks will have Internet access, but will be separated from each other.
That is what you need to accomplish.
Check/research if RT-AC68U can be set like this.
Hope it helps
Cheers,
Mike
12-25-2018 02:26 AM
01-10-2019 11:41 PM
I returned the switch as it did not do what I wanted it to and I will use my ASUS routers then connect another separate router from these to the apartment.
