Simple ACL Not Working
cfrasnelly
Hi there,
I have what I thought would be a simple ACL.  See the attached overview.  I have applied an ACL to a port connected to a Dell switch.  All the machines on this Dell switch live on the 172.10.x.x network.  I have a single server (on another subnet) hanging off the Cisco switch that I want to allow traffic to as well as a couple of machines hanging off the Cisco that belong to the 172.10.x.x network that need to communicate over to the Dell switch.  Here was my thought process:
1 – Allow all traffic FROM a 172.10.x.x address TO a 172.10.x.x network (Handles both directions)
2 – Allow all traffic FROM a 172.10.x.x address TO address 172.20.100.100  – Ingress
3 – Allow all traffic FROM 172.20.100.100 to any 172.10.x.x address - Egress
4 – Apply to port connecting Cisco switch to Dell switch
When I apply the ACL I am unable to ping 172.10.0.50 from 172.20.100.100 - what am I missing?!?!?!
Thanks!
David Hornstein
Level 7
Level 7
The subnet masks in your PDF look wierd, the switch is using reverse masking so the address and mask would be,
but the switch looks at ingress not egress.
172.10.0.0  mask= 0.0.255.255  to 172.20.100.100  mask=0.0.0.0
172.20.100.100  mask=0.0.0.0  to 172.10.0.0  mask=0.0.255.255
there are plenty examples of access-list for 300 series switches within this community, try a search and see what you get for more examples.
regards Dave
David Hornstein
Level 7
Level 7
regards Dave
cfrasnelly
Sometimes I take things a bit to literally... thanks David.
Sometimes i wish we didn't use inverse masking on ACL.  But I am glad you are up and running.
regards Dave
