Hi Guys
I have a SRP527 router with a normal 2.2 dbi antenna, I want to replace this with a more powerfull antenna but it seems its fixed to the box.
Is it possible to replace this?
I am using the router as a 3G router only and no ADSL and i would like to boost the 3G signal strength, if there is a way of doing this with out the antenna please advise aswell.
I am assuming there shouldn't be any drawbacks from this action, is that right or there are some pit falls to consider?
I want to replace it with a 11dbi external antenna, this is not a cisco antenna.
Thank you in advance for your help
Dumisani
