SRW2008 - How To Enable Jumbos Frames?
gmcdowell
Title says it all....
How do you enable jumbo frames on an SRW2008?
The data sheet says it supports jumbo frames, but the manual does not say how to enable, and I did not find it in the Web GUI.
It just occured to me (light dawns on marblehead) - perhaps this needs to be done via the CLI?
TIA.
Steven DiStefano
ADMIN --> Jumbo Frames (checkbox) on the GUI for the switch.
Ganesh Hariharan
TIA.
Check out the below link
http://portforward.com/routergui/Linksys/SRW2008/Jumbo_Frame.htm
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
