Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2871 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4423 Views
  • 1 replies
  • 16 Helpful votes
Hi,We have recently had a SRW248G4 switch and I have been carrying out some tests for a new computer suite.  I have found via carrying out bandwidth tests that the fibre is only giving me 30 MB/s.  Other switches on my network (netgear, 3com) give ar...
I have a new SRW208G switch and what I want to do seems very simple but so far I am unable to figure out how to do it.DSL Modem/Router connected to g1 (It could be connected to one of the "e" ports if more appropriate). DSL Modem/Router is also the D...
JonesBayCo by Level 1
  • 2084 Views
  • 11 replies
We have a strange problem in our network.We have recently replaced all of our existing 3Com switches with the new Linksys SRW248G4P. Main reason behind this change was to have PoE based IP-Phones implemented over existing network cabling.We are using...
imrannmdc by Level 1
  • 1544 Views
  • 2 replies
How can partners obtain an equipment demo of the following gear:·         Cisco Small Business Managed Switch - 48ports - Ethernet, Fast Ethernet, 10Base-T, 100Base-TX + 2x10/100/1000Base-T + 2xSFP - 1u - rack-mountable - stackable·         Cisco Sma...
I want to depoly 5 ESW 540-24 PoE switches in a network with depolyment of Polycom IP phones.As you know these switches come with QoS preconfigured for deployment of IP phones.Now I have general questions regarding advance QoS configuration done by C...
Using SFE2010 switches in both single mode and stacked mode. Want to config switch using saved tftp's config. I set up basics of switch including some nominal VLANs. Then save the running-config via tftp. Then I edit the rest of the ports for their d...
brezlerg by Level 1
  • 1670 Views
  • 5 replies
Hi,I'm trying to monitor my SRW2024 switches through the Opmanager Network Monitor Solution but unfortunately this solution doesn't have predefined monitors for Linksys Switches. I need to monitor the CPU, Memory and Backplane Utilization.I contacted...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
