Hi Staff,
Just a minor minor point for clarification , software version 1.1.2b or really 1.2.2b ?
Have you tried the following;
step 1. added a IP address of 10.10.10.X to that suspect switch.
step 2 saved the configuration change
step 3. associated that IP address to mangement vlan 2
step 4 made one port on the switch a 'access mode ' member of VLAN 2
step 5 saved the configuration change
Step 6. Plugged your PC onto that access mode port which is a member of vlan 2
Do you get a IP address in the 10.10.10 .X range allocated to your PC ?
step 7. If not , set you PC up in the 10.10.10.X network
Can you ping the IP address of the switch ? ( you have said that this answer is no)
Can you ping or any other device in VLAN 2 ? ( you have said that this answer is no)
If you followed the steps above, and the answer is still no then call the Small Business Support Center
regards Dave
