Hi all,
Here is my network toplogy ISP---->ASA----->SRW2048------>POE injector----->Phone
I have a weird situation. I have approximately 7 Cisco IP Phones connected to PoE injectors and connected to a SRW2048 switch. The phones will get a network unavailable error on screen and the switchport will be down physically.
If I plugged the phone directly into the ASA on one of the PoE ports the phones registers to the Call Manager
(By the way the Call Manager is in another building connected by Site to Site tunnel)
If I plug my laptop into the PoE injector and into SRW2048 I get an IP address.
If I plug the PoE injector into a small 8 port 10/100 workgroup switch and then plug it into the SRW2048, the phones work.
Is there some kind of setting in the SRW2048 that won't allow the phone to connect?
I also wiped the switch so it has the default configuration on it. We also have no VLANS.
