Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2905 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4482 Views
  • 1 replies
  • 16 Helpful votes
Hello to everyone.I am looking at the mac address table of a SF220-24P switch we have at the office.It's a POE FE switch we use chiefly for our Polycom phones, with the auto voice vlan feature enabled and in use.To give a little more detail, the port...
In the IPv4 Static Routing Table below, The switch is assigning a VLAN (and associated subnet) to a subnet/route that has zero access to my management network. How do I change the Default Route to VLAN1 and the subnet associated with VLAN1? This is a...
Dear All,I have 2 switches which are SF300-24.Switch 1 is connected to Internet Router for all clients on swith1 and switch 2.The clients on switch 1 & switch 2 don’t communicate each other.Port1~Port24 on switch 1 & switch 2 are isolated ports.Gigap...
Hi  I  tried to use VGRP between two SG500-52. but VLAN is not automaticly created on the second switch Could you help me please  The diagram of the network:Stack-SG500 gi1/1/50 <-----------------------> gi1/49 SG500VLAN 1VLAN 115 Configuration  Stac...
infologic by Level 1
  • 686 Views
  • 1 replies
Resolved! SG300-10 IP-Helper
Hello everyone,I'm trying to configure ip-helper on my SG300-10 but can't figure out how to do it. I've been using these steps to configure mine but i run into a stop at "Device(config-if)# ip helper-address 172.16.1.2" Here i don't have the command ...
nhj000001 by Level 1
  • 5594 Views
  • 3 replies
Dear team,we need to install 2 switches model sg300 24p with gvrp.I have followed the instructions to set this protocol but it doesn't work.I´ve tried with 2 differents firmwares.I just need create 15 vlans and  replicate in others 2 switches with th...
I have a really odd problem:I have an SG300 with a few VLANS and hosts plugged into them. the issue I have is:I have 2 ports set up as a LAG with a HP NAS attached to it, all other hosts except for 1 can communicate with the NASall the hosts, NAS, LA...
Tud by Level 1
  • 415 Views
  • 1 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
