08-04-2010 12:51 PM
We are looking to use some SRW2048 in replace of some 2960 switches. Do the SRW2048 support extended vlan ( 1-4094 )
Jason
08-04-2010 09:00 PM
Hi Jason,
The manual does state;
VLAN Management Tab - Create VLAN
The Create VLAN screen provides information and global parameters for configuring and working with VLANs.
VLAN ID (2-4094). Indicates the ID number of the VLAN being configured. Up to 256 VLANs can be created. This
field is used to add VLANs one at a time. To add the defined VLAN ID number, press the Add button.
VLAN Name.
Of course the default VLAN ( VLAN ID=1) is enabled by default on all ports.
Hope that helps
regards Dave
08-04-2010 09:36 PM
It is important to note that the SRW2048 is a layer 2 switch and does not support IP VLAN routing. It
will support VLANs but will not effectively route inbetween them.
