SRW224G4 firmware upgrade
airnetdtcibulka
Hi I have questionS:
1. Can I upgrade SRW224G4 in web browser from 1.2.1b to 1.2.2b boot version 1.0.2?
2. After firmware upgrade will be in switch the same configuration or default?
Thank you.
tcsillag83
The upgrade should work fine from a browser, i recently upgraded one of my switches.
Configuration should remain the same after the upgrade.
However, SRW series tend to have some problems, so:
- backup your configuration before upgrade (it's best practice to always backup all configs before any upgrade on any switch)
- have a serial console ready with Xmodem software, in case the upgrade goes bad...
Cheers,
Tamas
