SRW224G4 - POST - Fail
mudasirmirza
I have a Linksys SRW224G4 with me. I have successfuly connected the switch with console.
When i reboot the switch, it shows me something like this.
------ Performing the Power-On Self Test (POST) ------
UART Channel Loopback Test ......................... FAIL
After this message nothing comes up, its like the switch gets hanged up.
Sometime it actually works, but when it says " Autoboot 2 seconds to press ESC or RETURN" and even if i press ESC or Enter, nothing happens. Later on the switch reboots again by itself.
Can anyone help me out in this matter.
Basically i forgot the password which i had set about 6 months back, now i am stuck.
Looking forward for a quick and positive reply.
alissitz
Level 4
Level 4
If it is still under warranty, I would suggest calling our support center.
You can find the links for the support center on this page, look to the right hand side of the web page:
https://www.myciscocommunity.com/community/smallbizsupport
HTH,
Andrew Lissitz
Dear,
Thanks for the reply. The switch is not in warranty any more. Can it be fixed or not.
