03-01-2011 11:04 AM
What are the airflow requirements for the above switch? If I need to permanently mount it in a fully enclosed (not air tight) electrical box, will I be setting myself up for failure down the road?
Chris
03-01-2011 01:45 PM
Ideally, you want to keep give these devices an ample amount of air flow any way possible. Especially with this being a poe switch.
Log in to Community
