Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board from June 18th - July 18th. These dates are subject to change pending progress. This in...
CoreyP319 by Cisco Employee
  • 628 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5560 Views
  • 1 replies
  • 16 Helpful votes
HI,We just purchased 3 Cisco SG200 50 Port Switch. Please bear with me because I am onlynew to Cisco switch and no nothing about IOS only rely on GUI. I also have a query on VLANSsettings. I am new to VLANS though I have read information about it and...
Hi GuysI was wondering if there was a difference between the Linksys SRW224G4 & Cisco SF300-24 switches. Going through the support docs I see the SF300 has limited L3 functionality in terms of being able to establish static routes between VLANS. Any ...
Добрый день!Несколько общих фраз для того чтобы было понятно в чем дело:Есть dhcp сервер ( isc dhcp 3.0.5) работает с 82 опцией, адреса раздает L2 уровню sps224g4, они соответсвенно relay, добавляют 82 опцию в запрос от пользователя.Есть коммутаторы,...
I have a new install with 3 SF300 switches, setup as vlan 2, the switch connected directly to the 2901 router has no problems, plug in a phone and it gets an IP, but if connected to either of the two swtiches behind the first switch, they do not get ...
Hello, I have a Linksys SRW2008MP that I am trying to reset to factory defaults. The guy who set this up is no longer employed at my company, and I do not know the IP address to login with a web browser. The switch does not have a reset button on the...
For test I used 2 Switch that name "ESW X" and "ESW Y"I have 2 network that I named "Network A" and "Network B"I build 2 VLAN for each network that named Vlan 2 for Network A and Vlan 3 for Network B, I don't use Vlan 1 because it's the default VlanC...
adbemmaus by Level 1
  • 1938 Views
  • 2 replies
PID VID:        SLM2016T V01 Firmware Version:       1.0.0.19Is this known bug that you cannot backup (export) full running or startup config from this switch?  Will this be fixed in next firmware? (btw, still no new firmware with CDP support for thi...
Hi:I have designed my network as Follows:Cisco Catalyst 3750G Stack as the Core SwitchesCisco ESW 500 Switches as the Edge switchesI am trying to configure Spanning tree on my network with The Core Switches as the root. But i am having a problem with...
The switch functions and operates fine but I can no longer login to the webview(GUI) and when I use a serial cable to console in to it, it shows nothing on the hyperterminal meaning no login. How can I get back into the switch to manage it or reset i...
Hi guys,In a bridged  IEEE 802.5 and or Tokenring network, which combination of bits indicate to the source that a packet has been forwarded across a bridging device? is it though the hearder of the pocket or PAT? Thanks.
Hello,I have a SRW2008 that I have configured with several VLANs. My router (RVS4000) is trunked to port 8 on the SRW2008 and my WAP (WAP4410N) is conected on port 4 of the SRW2008. I recently added two wireless devices to VLAN 1 which I was able to ...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
