SRW248G4P stopped at Enter Transition mode ... Help
nayib
I have a switch SRW248G4P  that doesn't work.
I already updated the OS (1.0.1 ,  1.0.2 , 1.3.1), and it always stop at the same part/message (Enter Transition mode...) during the boot.
The message at boot from the serial port is as following:
Image Loader 1.0.1
Loading Diagnostic Image File : SRW224G4P_SRW248G4P_boot.bix
Diagnostic 1.0.1
User Mode
--- Performing Power-On Self Tests (POST) ---
DUMMY Test 1 ................. PASS
UART Loopback Test ........... PASS
POE UART Loopback Test ....... PASS
DRAM Test .................... PASS
Timer Test ................... PASS
Done All Pass.
------------------ DONE ---------------------
Loading Runtime Image File : SRW224G4P_SRW248G4P_image.bix
Runtime 1.0.1
Pass
root init done
Set Transition mode ...
[get stackingMac done ret_val] = 1
Assigned Unit ID:[1]
stacking DB: unit = 0, module type = 0
Finish Set Transition mode ...
The files once you stop the boot sequence with Control-U are:
File Name                         S/Up Type Size       Create Time
$logfile_1                          0    3         64  1193046:28:15
Factory_Default_Config.cfg          0    5        354  24:01:02
SRW224G4P_SRW248G4P_boot.bix        1    1    1377600  00:00:44
SRW224G4P_SRW248G4P_image.bix       1    2    3517776  00:02:58
certificate                         0    8      18040  24:00:55
startup-config                      1    5       5675  24:04:46
startup1.cfg                        0    5       5537  24:01:13
Free Space : 2097152
[X]modem Download  [D]elete File  [S]et Startup File
[Q]uit
Select>
How can I resolve this issue, or is this definitely a dead unit?
Thanks is advance,
Nayib
0 Replies 0
