I have a switch SRW248G4P that doesn't work.
I already updated the OS (1.0.1 , 1.0.2 , 1.3.1), and it always stop at the same part/message (Enter Transition mode...) during the boot.
The message at boot from the serial port is as following:
Image Loader 1.0.1
Loading Diagnostic Image File : SRW224G4P_SRW248G4P_boot.bix
Diagnostic 1.0.1
User Mode
--- Performing Power-On Self Tests (POST) ---
DUMMY Test 1 ................. PASS
UART Loopback Test ........... PASS
POE UART Loopback Test ....... PASS
DRAM Test .................... PASS
Timer Test ................... PASS
Done All Pass.
------------------ DONE ---------------------
Loading Runtime Image File : SRW224G4P_SRW248G4P_image.bix
Runtime 1.0.1
Pass
root init done
Set Transition mode ...
[get stackingMac done ret_val] = 1
Assigned Unit ID:[1]
stacking DB: unit = 0, module type = 0
Finish Set Transition mode ...
Enter Transition mode ...
The files once you stop the boot sequence with Control-U are:
File Name S/Up Type Size Create Time
$logfile_1 0 3 64 1193046:28:15
Factory_Default_Config.cfg 0 5 354 24:01:02
SRW224G4P_SRW248G4P_boot.bix 1 1 1377600 00:00:44
SRW224G4P_SRW248G4P_image.bix 1 2 3517776 00:02:58
certificate 0 8 18040 24:00:55
startup-config 1 5 5675 24:04:46
startup1.cfg 0 5 5537 24:01:13
Free Space : 2097152
[X]modem Download [D]elete File [S]et Startup File
[Q]uit
Select>
How can I resolve this issue, or is this definitely a dead unit?
Thanks is advance,
Nayib
