Stacking CBS350-24T-4x with more then 4 Units
Rob87
I have in 3 Cases Units of the CBS-Series. In One Case are 2 Units and they are configure as Stack. Now I'd like to add the ohter cases.
In One Case are 1 Unit and in the secound Unit are 2 Units.
Im Summery I Have 5 Unit. how can i Confiure them as a Stacking Unit?
marce1000
 - FYI : https://www.cisco.com/c/en/us/support/docs/smb/switches/Cisco-Business-Switching/kmgmt2836-Stacking-Guidelines-for-CBS.html
 M.
thanks, I know how to configure Stacking, My Problem is that I can only choose Unit ID from 1-4, but I have 5 Units.
Is It Possible to use 5 Units?(And How do Ihave to Configure them)
The Last Unit (5.) I have to buy in the next 2 Weeks. Should I Buy an Other One?
What would be the Best Practise Solution for that szenario?
 - As per this document , https://www.cisco.com/c/en/us/support/docs/smb/switches/Cisco-Business-Switching/2899-2544-stack-settings-cbs-switch.html
  following the menus and settings you are clearly limited to 4 Units (only)
 M.
