10-21-2015 09:13 AM
Switch Multi-Layer (Layer-3)
hello community, I need help in this topology.
network topology.
# Switch / 1000 CISCO - SG300 28P - SW CORE
# Switch / 1000 CISCO - SG300 28P - SW DISTRIBUTION
# Switch / 100 CISCO - SF300 28P - SW ACCESS PRODUCTION
# Switch 3com / 1000 8P - SW ACCESS CAD
# HP switch / 16P 100 - SW ACCESS ADMIN
# HP / 100 switch 16P - SW DIR ACCESS
VLAN1 - IT - 192.168.1.0/24
VLAN2 - PRODUCTION - 192.168.2.0/24
VLAN3 - CAD - 192.168.3.0/24
VLAN4 - ADMIN - 192.168.4.0/24
VLAN5 - DIR - 192.168.5.0/24
VLAN6 - MEETING - 192.168.6.0/24
VLAN7 - SERVICE - 192.168.7.0/24
VLAN8 - CONNECTIVITY ASSETS - 192.168.8.0/24
VLAN9 - PRINTERS - 192.168.9.0/24
VLAN10 - SERVERS - 192.168.10.0/24
VLAN11 - DVR CAMERA - 192.168.11.0/24
my intention is to make up the subnets communicate to achieve the server, also i would to enable relay dhcp to receive the ip from the server that is at the swcore.
Doubts;
- Where i set ips interfaces? sw-core or sw-distr? or both?
- What are the steps to make this scopo to work?
- I could not enable spanning tree that sw model.
Thank you so much,
10-23-2015 02:47 AM
hello
there are two options how to set them up:
both are valid, both depend on many factors, like:
and each has its own advantages/disadvantages:
obviously to make connectivity working between all parties you have to set up both manageable switches (core and dist). other switches from yellow group you can keep untouched. and configuration steps are pretty clear:
