Switches crashing weekly
jsherald1971
Trying to determine cause of seven switches failing, all at the same time - occurring approximately on a weekly basis.
SF300-48 48-Port 10/100 Managed Switch Flash Memory log from this morning:
2147480013 2016-Apr-20 08:23:33 Emergency %SYSLOG-F-OSFATAL:   FATAL ERROR: GOAH: ABORT DATA exception  ***** FATAL ERROR *****  SW Version  :  1.4.5.02 Version Date:  20-Apr-2016 Version Tim e:  12:22:49 Instruction            0x7784A4 Exception vector       0x10 Program state register 0x60000013 0x0077844c 0x0021cf80 0x0021d188 0x00224e58   0x0022694c 0x00226a2c 0x00226d50 0x0022744c 0x0022801c 0x00228140 0x0022b798 0x001223f0 ***** END OF FATAL ERROR *****
2147481665 2016-Nov-30 09:31:16 Emergency %SYSLOG-F-OSFATAL:   FATAL ERROR: GOAH: ABORT DATA exception  ***** FATAL ERROR *****  SW Version  :  1.4.5.02 Version Date:  20-Apr-2016 Version Tim e:  12:22:49 Instruction            0x7784A4 Exception vector       0x10 Program state register 0x60000013 0x0077844c 0x0021cf80 0x0021d188 0x00224e58   0x0022694c 0x00226a2c 0x00226d50 0x0022744c 0x0022801c 0x00228140 0x0022b798 0x001223f0 %SYSLOG-F-OSFATAL:   FATAL ERROR: GOAH: ABORT DATA exception   ***** FATAL ERROR *****  SW Version  :  1.4.5.02 Version Date:  20-Apr-2016 Version Time:  12:22:49 Instruction            0x7784A4 Exception vect
2147483494 2016-Nov-30 09:27:56 Emergency %SYSLOG-F-OSFATAL:   FATAL ERROR: GOAH: ABORT DATA exception  ***** FATAL ERROR *****  SW Version  :  1.4.5.02 Version Date:  20-Apr-2016 Version Tim e:  12:22:49 Instruction            0x7784A4 Exception vector       0x10 Program state register 0x60000013 0x0077844c 0x0021cf80 0x0021d188 0x00224e58   0x0022694c 0x00226a2c 0x00226d50 0x0022e9f8 0x0022eaf8 0x0022801c 0x00228140 0x0022b798 0x001223f0 ***** END OF FATAL ERROR *****
Appears to have failed, then rebooted, failing twice more.
The remaining switches all have similar logs, failing and rebooting within 3-4 minutes of each other.
Michal Bruncko
Level 4
Level 4
thats too few information in order to recommend or even think about possible issue - even more if they are all crashing in row (as per your description). the best would be to raise service request to Support - Small Business Support Center (SBSC) as these crashes are usually not explanatory with only high technical info suited for vendor support.
I was able to manually reproduce this issue by running an nmap scan on the network.
See this post: https://supportforums.cisco.com/discussion/13071686/system-crash-again#comment-11569081
I'm assuming this is a known issue to Cisco...
