Showing results forĀ
Search instead forĀ
Did you mean:Ā
Switching Power adapter for For SG300-10SFP or SG350-10P switch
Sadekul Rimon
I need Switching power adapter for both SG300-10SFP or SG350-10P Cisco switch. Before It was FSP-090 DMBC1 but this power cord cable is not available now. Instead the vendor offered me FSP-090 AWAN3 . I need to know that is FSP-090 AWAN3 is compatible with cisco switch mentioned earlier ?
marce1000
 -  Look at datasheet https://www.fsp-group.com/download/pro/FSP090-AWAN3_Datasheet.pdf  and compare with the powering requirements of the Cisco device ,
 M.
Power output is 90 watt for both of them. Output voltage also same, 54V. And it also provides 4 PIN cord. Output Current is also same, 1.67A. Any other issues that might be incompitable with one another ?
Thanks for your Answer in Advance
        - None !
 M.
