Showing results forĀ
Search instead forĀ
Did you mean:Ā
System crash again ...
pokemon
Hi All,
Have you ever seen below message on SG500 switch before ?
Jul 12 04:21:18 atviesw01 1 2016-07-12T02:21:17Z atviesw01 SYSLOG - OSFATAL - %S
YSLOG-F-OSFATAL: FATAL ERROR: GOAH: ABORT DATA exception ***** FATAL ER
ROR ***** SW Version : 1.4.5.02 Version Date: 20-Apr-2016 Version Time: 12:24:28 Instruction 0x7F8434 Exception vector 0x10 Program state register 0x60000013 0x007f83dc 0x0023e74c 0x0023e954 0x00246624 0x00248118 0x002481f8 0x0024851c 0x00248c18 0x002497e8 0x0024990c 0x0024cf64 0x001223f0
Actually we have migrated a office from a MPLS provider to new MPLS provider.
Then we have renewed the older switch with SG500 as well.
As the last step, I wanted to check all devices in this office and ran NMAP to entire IP range for this office.
Then switch crashed with above error message.
atviesw01#sh ver
Unit SW version Boot version HW version
1 1.4.5.02 1.4.0.02 V03
atviesw01#
Is this normal behavior ?
The interface configuration where I ran NMAP is quite simple ...
atviesw01#sh run int gi1/1/12
interface gigabitethernet1/1/12
no negotiation
description "Virtual Machine"
switchport trunk native vlan 989
atviesw01#
Please help ..
Miyoshi
Philip D'Ath
It is most likely to be a software defect.  Is the firmware up to date?
Thanks Philip,
Yep, as far as I can see at cisco.com, I'm using the latest version of boot code and firmware version..
Miyoshi
Lance L
I am having the same exact problem with SG300 switches.
The following nmap command will cause any switch running 1.4.5.02 to crash.
nmap -sS -T3 -A -F
We have some switches running 1.3.0.62 which appear unaffected.
