Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3508 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5181 Views
  • 1 replies
  • 16 Helpful votes
I have a SG300 that is running 1.4.5.02 and need some help with ACL's. My intention is to lock things down where services aren't accessible from the outside. Here is the configuration at the moment. We've tested and SSH and HTTPS are accessible from ...
phusion2k by Level 1
  • 743 Views
  • 0 replies
Hi, I am pretty new to networking with Cisco equipment, but we have had an RV325 now for a while that I've gotten used to and have a couple VLANs set up on. We had been running with just the RV325 and a WAP371 supporting about 35 associated devices a...
joey.khan by Level 1
  • 660 Views
  • 2 replies
I have 9 PCs at a SG300-10 switch running. Everything works fine, however, in the RAM memory log I can see permanently DOWNs and UPs. What is the reason for that behaviour? Another swtich SG300-20 does not show this behaviour.214748332717/12/12 10:10...
Hello, I was hoping someone could help with a potentially easy (stupid) question.  I have powered up the switch and the system light is blinking green.  Now I want to and want to add it to an existing network.  According to the quick start guide, whe...
tladd0001 by Level 1
  • 604 Views
  • 2 replies
We have 2(two) SG300-28 switches. We have several VLANS that need to be truked between switch A and switch B 1. We are able to create 1 TRUNK port  that includs vlan 2,3,4 and it works fine between switch A and B.  We are now trying to create a 2nd T...
soupensu by Level 1
  • 383 Views
  • 0 replies
Hi guys, So here's the setup: 2 switches: Switch1 3560x Switch2 3560x (10gbe c3kx-nm-10g module) 3 vlans: 1(default) 200 (storage) 201 (vmotion) poweredge servers: a blade m1000e chassis with 10gbe pass through module esxi for ose on the blades. ...
cposenjak by Level 1
  • 534 Views
  • 0 replies
Anyone have an opinion on this?Setup:An sg300-10 configured in L3 mode.There are 4 vlans defined (with 4 IPv4 addresses, though the sg300 is not routing -- other device does).In IPv4 all works fine.Trying to add IPv6 to my network I found out that:- ...
n.sinanis by Level 1
  • 5978 Views
  • 12 replies
I have a couple of SG300 28 port switches that I just purchased over the last few months, we changed out our phone system so we using voice over IP phones and the phones are now connected to our pc's.  For some reason, the ports are dropping on the s...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
