Telnet Cisco SF300-08
tnhafiz87
Hello guys...I just bought this switch last week.I tried to telnet this swtich using my laptop(windows 7 64-bit),but i failed.I suspect that this problem came from my laptop because i dont change any default ip setting of the switch.
There are 2 things that ive tried to solve this problem:
1) Start --> control panel --> Programs --> click "turn windows features on or off" --> tick "telnet client"
2) Start --> search "services" --> telnet --> startup type "automatic"
but stil I cannot telnet the switch. The error is "could not open connection to host on port 23: connection failed"
Please help me. Thank you
Tom Watts
Hi Hafiz, by default the switch does not accept telnet connection. Log in to the GUI then go to  Security -> TCP/UDP services and check the box for telnet and apply.
If it doesn't work then, it's a problem with the computer.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom Watts
-Tom
Thank you so much Tom Watts. It works. I really appreciate your help
