Tracert and vlans problems
i set up few vlans on my sf300. Everything working fine. i can access internet from all vlans, ping...etc. The only problem when i tracert from any vlan, i am always failling the first hop. My firewall is disabled as well as my antivirus.I was wondering is this normal or am i missing something?default gateway on my PC is vlan IP.
Thank you
Tracing route to google.com [173.194.70.113]
over a maximum of 30 hops:
  1     *        *        *     Request timed out.
  2     1 ms    <1 ms    <1 ms  192.168.1.1
  3     1 ms     1 ms     1 ms  192.168.100.1
My configuration:
switch1#sh run
config-file-header
switch1
v1.2.9.44 / R750_NIK_1_2_584_002
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 2-4
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp relay address 10.10.4.2
ip dhcp relay enable
ip dhcp information option
bonjour interface range vlan 1
hostname switch1
no passwords complexity enable
username cisco password encrypted f84f7bb9b5e52e3b755d7ec0496c50e8404869d8 privi
lege 15
ip telnet server
interface vlan 1
ip address 192.168.1.254 255.255.255.0
no ip address dhcp
interface vlan 2
name "x"
ip address 10.10.2.1 255.255.255.0
interface vlan 3
name "y"
ip address 10.10.3.1 255.255.255.0
interface vlan 4
name Server
ip address 10.10.4.1 255.255.255.0
interface fastethernet1
switchport mode access
switchport access vlan 2
interface fastethernet2
interface fastethernet3
interface fastethernet4
switchport access vlan 3
interface fastethernet5
interface fastethernet6
interface fastethernet7
switchport access vlan 4
interface fastethernet8
ip route 0.0.0.0 0.0.0.0 192.168.1.1
switch1#
14 Replies 14
Tom Watts
It looks like you have a default route to 192.168.1.1. What is 192.168.1.1?
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
192.168.1.1 is my internet gateway
Hi Mustapha, I'd suspect that default route may be causing the odd hop count.
-Tom
Thank you for your reply
So what do you think the default route should be?192.168.1.1 is my isp modem
Shouldn't need one, especially if it is the only internet gateway.
-Tom
Well actually i am using two routers isp router and a linksys e3000 between isp and switch. Isp router is 192.168.100.1
E3000 192.168.1.1. I am using the e3000 for nating since i couldnt configure static routes on my isp router.
Anybody??
Remove the default route...
-Tom
When i remove default route, i will no longer have access to the internet. I noticed when i am on the default valn 1 tracert works normally and the first hop is 192.168.1.254
Hi Mustapha, if that default is required for internet connectivity then something else is wrong. You should not have to manually add a default route on the switch.
Reference this topic-
https://supportforums.cisco.com/thread/2123434
The only requirements will be vlan interface with IP addresses and a static route pointing back to the SVI on the router. Anything more is uncessary.
Under a normal circumstance if you trace route from host a in vlan 1 to host b in vlan 2 locally connecting to the switch, there is only 1 hop - the switch.
Your default route is telling all traffic to go somewhere else...
-Tom
So without the default route how would the switch know where to send packets to the my internet gateway 192.168.1.1
Because the switch maintains a route table. When you create a SVI and have active links on the SVI, it builds a route table.
-Tom
Hi Tom, Nice info.
Uhhhhhhhhhh, yeah...im gonna have to side with Mustapha.  Upon cursory examination, idk what the rest of you are smokin but it must be stout.  Is it that they used the "ip route 0.0.0.0 0.0.0.0" command instead of "ip default-gateway" that has this group all bent out of shape?
Admitedly I've never worked with an sf300 but it appears to be a switch that can route...it doesn't appear to be running any routing protocols so how in the hell could it ever, possibly know where to go to get out???
Lets hang 2 c6807's off each of the 3 vlans, so a total of 6 HONKIN cat's.  Lets give them L3 vlan interfaces and lets also hang hundreds of endpoints off all 3 vlans.  So now vlan 1 has 192.168.1.2 - 192.168.1.253 ALL USED UP, not one single free ip in that little fella...and lets NOT set a default gateway for sf300.  LETS ALSO SAY that your life depends on pinging google from the commandline of the sf300, will you survive...without adding a default gateway?
