Trusted DHCP server SG200-26P
EdwinDijk9278
I recently got 2 SG200-26P switches. Now I want to set a trusted DHCP server in their configuration since I don't want somebody coming into my network( Using these switches for LAN-party's) and run a DHCP server themselves. How or where in this web GUI can I put in a trusted dhcp server IP or port?
Kind regards
riteshsh
My name is Ritesh Sharma from Cisco TAC.
The DHCP trust/untrust ports can be created by enabling a feature called DHCP snooping in the switch.
However, SG200 is L2 switch only, so this mean switch will not support dhcp snooping.
It is supported on switches SG300/500, Sg350/550 etc.
Please mark this as helpful of it resolves your query.
Ritesh Sharma
riteshsh
Ritesh Sharma
I want to disable dhcp from my cisco sg200 28p,
i need to keep my switch default IP address
