Trying to conect 2 sge200 series swiches over gbit /fiber
Saulo Loor
       Hello            I have a stack of 6 switches and I want to add another over the gbit connector using fiber.
I already connected but I can acces the network from the new switch.
I don't have any issues on my Stack all resources are available
Do I need to do some special setup or connection to enable this?
Can be stacked like the others? I already usen the 2 stacking port can i Add another switch?
Tom Watts
Hi Saulo, you may have up to 8 units in the stack. Just make sure the new box is on the same firmware then you may add to a free stack port
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Thanks for your reply,
My unit is already using ports 24,48 can I connect another stack on 23 or 47 (23,47 are the same of ge3,ge4?).
or do I need to daisychain with another gbit using port GE2,GE1 ?
I believe the switch has only 2 stack ports, 24/48 are combo port to the ge1/ge2. you'd have to hang off a new switch somewhere else.
-Tom
