Unable to add vlan to trunk interface
cewege
I've acquired a new Cisco CBS 220 24P 4X and I've an issue to add VLAN into trunk interfaces.
Switch9E8FD1#conf t
Switch9E8FD1(config)#int gi24
Switch9E8FD1(config-if)#switchport trunk allowed vlan add 2,3,4,10
Switch9E8FD1(config-if)#end
Switch9E8FD1#wr mem
Building configuration...
[OK]
And when I check my running conf :
Switch9E8FD1#sh run
config-file-header
CBS220-24P-4X
Switch9E8FD1
v2.0.2.8
CLI v1.0
username "(hidden)" privilege admin secret 8 (hidden)
sntp server pool.ntp.org
sntp server time-a.timefreq.bldrdoc.gov
sntp server time-b.timefreq.bldrdoc.gov
sntp server time-c.timefreq.bldrdoc.gov
sntp server time-pnp.cisco.com
vlan 2
 name "infra"
vlan 3
 name "admin"
vlan 4
 name "outils"
vlan 10
 name "cwg_lan"
vlan 11
 name "ie_lan"
vlan 12
 name "lan_regie"
vlan 20
 name "cwg_wlan"
vlan 21
 name "ie_wlan"
vlan 22
 name "regie_wlan"
vlan 40
 name "guest"
vlan 100
 name "dmz_basse"
vlan 101
 name "dmz_haute"
vlan 1000
 name "troll"
voice vlan oui-table add 00:E0:BB 3COM
voice vlan oui-table add 00:03:6B Cisco
voice vlan oui-table add 00:E0:75 Veritel
voice vlan oui-table add 00:D0:1E Pingtel
voice vlan oui-table add 00:01:E3 Siemens
voice vlan oui-table add 00:60:B9 NEC/Philips
voice vlan oui-table add 00:0F:E2 H3C
voice vlan oui-table add 00:09:6E Avaya
spanning-tree mst configuration
 name "(hidden)"
ip ssh server
ip ssh password-auth
no ip http server
no ip http secure-server
interface gi1
 switchport access vlan 10
interface gi24
 switchport mode trunk
 description "cwglan"
interface te1
interface te2
interface te3
interface te4
As you can see, gi24 doesn't have my vlans. There are only trunk mode set few minutes ago and interface description.
I've disabled web interface to avoid conflicts.
Why is it not working ?
Thanks in advance.
Best regards.
cewege
Ok I think I've found the solution.
CDS220 doesn't work like 2960X ; for my usage, I need to set interface to "general" and not "trunk" to let specific tagged vlan on interface (https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/CBS_250_350/CLI/cbs-350-cli-/vlan-commands.html#wp8381803720)
So for my config :
Switch9E8FD1(config-if)#switchport mode general
Switch9E8FD1(config-if)#switchport general allowed vlan add 2-4,10 tagged
interface gi24
and it's work like expected.
Maybe someone can confirm it's the best practice ?
6 Replies 6
M02@rt37
Hello @cewege,
please type
Switch9E8FD1#sh int trunk
You will see the vlan allowed ont your trunk port, e.g gi24
Best regards
Thanks for your quick reply
Here's command results :
% bad parameter value
Switch9E8FD1#sh int trunk gi24
Switch9E8FD1#sh gi24 trunk
Unknown command
Switch9E8FD1#sh int
  GigabitEthernet     Gigabit ethernet interface to configure
  Port-Channel        IEEE 802.3 Link Aggregateion interface
  TenGigabitEthernet  10 Gigabit ethernet interface to configure
  protected-ports     Protected ports information
  status              Interface status
  switchport          switchport
Switch9E8FD1#sh int GigabitEthernet24
GigabitEthernet24 is up
  Hardware is Gigabit Ethernet
  Auto-duplex, Auto-speed, media type is Copper
  flow-control is off
  back-pressure is enabled
     1589 packets input, 105318 bytes, 0 throttles
     Received 1515 broadcasts (14 multicasts)
     203 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     14 multicast, 0 pause input
     5690 packets output, 1246343 bytes, 0 underrun
     0 PAUSE output
Switch9E8FD1#sh int GigabitEthernet24 trunk
Unknown command
Sorry @cewege ,
#sh int switchport
And share the output, thanks.
https://www.cisco.com/c/en/us/td/docs/switches/lan/csbss/CBS220/CLI-Guide/b_220CLI/vlan_commands.html#ID-000056c3
Best regards
Switch9E8FD1#sh int switchport gi24
Port : gi24
Port Mode : Trunk
Gvrp Status : disabled
Ingress Filtering : enabled
Acceptable Frame Type : all
Ingress UnTagged VLAN ( NATIVE ) : 1
Trunking VLANs Enabled: 1-4094
Port is member in:
 Vlan            Name              Egress rule
    1                default       Untagged
    2                  infra         Tagged
    3                  admin         Tagged
    4                 outils         Tagged
   10                cwg_lan         Tagged
   11                 ie_lan         Tagged
   12              lan_regie         Tagged
   20               cwg_wlan         Tagged
   21                ie_wlan         Tagged
   22             regie_wlan         Tagged
   40                  guest         Tagged
  100              dmz_basse         Tagged
  101              dmz_haute         Tagged
 1000                  troll         Tagged
Forbidden VLANs:
 Vlan            Name
I don't understand by all vlan are set by default.
So I've reset gi24 :
Switch9E8FD1(config)#default interface gi24
Interface gi24 set to default configuration
Now, it seems ok :
Switch9E8FD1(config)#exit
Port : gi24
Port Mode : Access
Port is member in:
    1                default       Untagged
Forbidden VLANs:
 Vlan            Name
But when I set VLAN I want on this interface, all VLAN are tagged by default :
Switch9E8FD1(config-if)#switchport trunk allowed vlan add 2-4,10
Port gi24: Port mode is not trunk
Switch9E8FD1(config-if)#switchport mode trunk
Port : gi24
Port Mode : Trunk
Port is member in:
    1                default       Untagged
    2                  infra         Tagged
    3                  admin         Tagged
    4                 outils         Tagged
   10                cwg_lan         Tagged
   11                 ie_lan         Tagged
   12              lan_regie         Tagged
   20               cwg_wlan         Tagged
   21                ie_wlan         Tagged
   40                  guest         Tagged
 1000                  troll         Tagged
Forbidden VLANs:
 Vlan            Name
I'm.... I don't know what's happening.
Have I missed something ?
Best regards.
cewege
So for my config :
interface gi24
You find! Happy for you @cewege.
Best regards
