Unusal LED Indicatio in Cisco 2960x-24TSL switch
Ibrahim Bhuiyan
I have a Cisco 2960x-24TS-L switch. I use it in my network. but recent has seen some unusual LED indication in the front panel. But switch is running well. and I can login via telnet. I did not find any error message in log.
Also after removing from the network when I ON the switch, the uplink port LED is ON state automatically
Please can anyone tell me what is the problem? Is it hardware issue or IOS bug issue?
saif musa
Level 4
Level 4
Could you please explain what you mean by "the uplink port LED is ON state automatically"
I'm really confused!
Yes. This is Uplink port LED. In the right side of switch there are 4 uplink port. I attached the picture. you can see there.
Hi Ibrahem,
These are not uplink led, these are SFP port LED indicators. Chick attachment, also this is strange behavior of LEDs I think its something related to BUG, Im wondering what will happened if you shutted down those ports and enable it again ? lets give it a try.
Thanks Saif,
Yes those are SFP port. But don't need to wonder. Because I restarted it several time but it remains same condition.
