VLAN ESW-540
albertmilia
I have a new switch ESW-540 24-port, I upgrade firmware to 2.1.19.
I build 2 VLAN for 2 networks: VLAN 2 and VLAN 3 . I don't use the default VLAN 1.
This is my configuration:
port e1 and e2 : ACCESS PORT on UNTTAGGED VLAN 2
port e3 and e4 : ACCESS PORT on UNTTAGGED VLAN 3
port e1,e2,e3,e4: EXCLUDED VLAN 1
port e24: TRUNK PORT with UNTAGGED VLAN 1 and TAGGED VLAN 2 and VLAN 3
Communication (ping) between e1 and e2 --> OK
Communication (ping) between e3 and e4 --> OK
Communication (ping) between e1,e2 and e24 --> NOK  :-(
Communication (ping) between e3,e4 and e24 --> NOK  :-(
Communication (ping) between e5,e6,e7,.... (VLAN1) and e24 --> OK
Communication (ping) between e5,e6,e7,.... (VLAN1) and VLAN2, VLAN3 --> NOK - It's correct.
Any special configuration on e24 trunk port ????
Can you help me ???
David Hornstein
Level 7
Level 7
Hi Albert,
Bit concerned about your testing process.  You have proved that untagged switch ports in vlan 1 can communicate with e24.  that makes perfect sense.
What what are you using (connected on e24 )  to check for tagged packets egressing out of E24 from PCs connected on  vlan 2 and vlan 3.  This testing device you are using must be vlan aware.
The switch port 24 must be connected to a VLAN aware router or layer 3 switch  that is trunked for ;
vlan1 untagged
vlan2 and vlan3 tagged.
So that routing can occur between vlans.
regards Dave
David Hornstein
Level 7
Level 7
Hi Albert,
vlan1 untagged
regards Dave
Indeed you are right,
I configured the VLAN support in Router connected to e24 and entirely correct.
Thanks for your help.
