VLan setting SG 550
athan1234
Level 3
Level 3
Hi there
I am stuck in this elementary situation.
I dont have access cable console only via remote destok client
A single path provider
The Dhcp LAN router is operational, however I am unable to access the SG500 default IP either HTTP or Putty (connecting distant deskotp clients).
Te pc i am conecting remote destok is in port 22 on the cisco sg  manual ip
Sufijo DNS específico para la conexión. . :
Vínculo: dirección IPv6 local. . . : fe80::ae1e:5701:9c3f:2de0%19
Dirección IPv4. . . . . . . . . . . . . . : 192.168.1.20
Máscara de subred . . . . . . . . . . . . : 255.255.255.0
Puerta de enlace predeterminada . . . . . : 192.168.1.1
When I turn off DhCP on the router, I am able to access Sg500.
Where is the issue?The plan is to link a Meraki AP (dhcp active) to a connected GSG 500 router via VLAN 1 for internet connectivity.
Port 24 .
As for myself, I intend to build an  vlan 2 for connecting tablets, for instance. nonetheless, I lost the Connection router after configuring the IP.
THe idea now is creating a new vlan for example 2 new on the  sg 500 for conecting
From x vlan give internet conexion  where is conectingf a ap meraki
other vlan only without internet conexion via static
marce1000
  - You mean you are unsure of the effective address of the device ?
    If so connect it to an IOS switch and issue the command show cdp neighbors detail
    then look at the device info at the port it was connected to , you will so see it's current address ,
 M.
switchd#show cdp neighbors detail
Device-ID: e0553de77910
Advertisement version: 2
Platform: Meraki MR32 Cloud Managed AP
Capabilities: Router Switch
Interface: gi1/0/24, Port ID (outgoing port): Port 0
Holdtime: 143
Version: 1
Duplex: unknown
Addresses:
IP 6.231.121.16
switchd6d761#show lld neighbors
System capability legend:
B - Bridge; R - Router; W - Wlan Access Point; T - telephone;
D - DOCSIS Cable Device; H - Host; r - Repeater;
TP - Two Ports MAC Relay; S - S-VLAN; C - C-VLAN; O - Other
Port Device ID Port ID System Name Capabilities TT L
gi1/0/23 a8:a1:59:e3:2e:ec a8:a1:59:e3:2e:ec O 281 9
gi1/0/24 e0:55:3d:e7:79:10 0 BR-AP08 W 11 0
gi1/0/48 84:a9:3e:09:23:8d 84:a9:3e:09:23:8d O 281 9
The provaider router is conecting on port 2
Flow Link Back Mdix
Port Type Duplex Speed Neg ctrl State Pressure Mode
gi1/0/1 1G-Copper -- -- -- -- Down -- --
gi1/0/2 1G-Copper Full 1000 Enabled Off Up Disabled On
gi1/0/3 1G-Copper -- -- -- -- Down -- --
gi1/0/4 1G-Copper -- -- -- -- Down -- --
gi1/0/5 1G-Copper -- -- -- -- Down -- --
gi1/0/6 1G-Copper -- -- -- -- Down -- --
gi1/0/7 1G-Copper -- -- -- -- Down -- --
gi1/0/8 1G-Copper -- -- -- -- Down -- --
gi1/0/9 1G-Copper -- -- -- -- Down -- --
gi1/0/10 1G-Copper -- -- -- -- Down -- --
gi1/0/11 1G-Copper -- -- -- -- Down -- --
gi1/0/12 1G-Copper -- -- -- -- Down -- --
gi1/0/13 1G-Copper -- -- -- -- Down -- --
gi1/0/14 1G-Copper -- -- -- -- Down -- --
gi1/0/15 1G-Copper -- -- -- -- Down -- --
gi1/0/16 1G-Copper -- -- -- -- Down -- --
gi1/0/17 1G-Copper -- -- -- -- Down -- --
gi1/0/18 1G-Copper -- -- -- -- Down -- --
gi1/0/19 1G-Copper -- -- -- -- Down -- --
The provaider router is conection on port 2
switchd#show interfaces status
Flow Link Back Mdix
switchd6d761#show mac address-table interface gi1/0/2
Flags: I - Internal usage VLAN
Aging time is 300 sec
Vlan Mac Address Port Type
1 d0:fc:d0:9d:72:88 gi1/0/2 dynamic
1 d0:fc:d0:b3:5a:5a gi1/0/2 dynamic
1 f8:8e:85:42:0b:0c gi1/0/2 dynamic
switchd#show run interface gi1/0/2
Empty configuration
  - The overall problem is still unclear for me; are you unable to access the sg550 ?
 M.
