VLAN Setup for VMware
stevend99
I'm new to creating VLANs on a Cisco switch, and I'm trying to create VLANs using the SG 300-10 for a VMware environment.  I'd like to use Virtual Switch Tagging on the ESX hosts, so I can use many VLANs over few physical NICs.  Plus using VST, I can just specify the VLAN ID (setup on the physical switch), on the port group for each VLAN.
I've changed the SG 300 to layer 3, as I'd like inter-routing between my VLANs.  This is the type of setup I'm looking for:-
VLAN1 - Default
VLAN 10 (192.168.10.1) to 20 (192.168.20.1) linked to ports GE3 & GE4.  I've connected port GE3 to ESX1 (vmnic2) and port GE4 to ESX2 (vmnic2)
The problem is when I check my physical network adapters (i.e. vmnic2) in vSphere, the IP Ranges for observed traffic in every VLAN specified for the configured port are not showing (i.e. networks 192.168.10.1 to 192.168.20.1)
I have attached screen captures of all my setup & configuration so far, I'm obviously making a mistake...
Could someone please advise what I'm missing?
Thank you
0 Replies 0
