VLAN. TRUNKING. BETWEEN. CISCO AND jUNIPER
kwanshe01
Hello. All, Please can. Anyone show or explain to me how to trunk vlan traffic from my new cisco sf300 switch to the exesiting juniper EX2200 switch. Your inputs are highly appreciated.
devils_advocate
Level 7
Level 7
I have not used any Juniper kit before so my answer will be for the Cisco side.
Firstly you need to make the port a Trunk port.
(Vlan Management > Interface Settings)
Then you set the native vlan to be untagged.
​(Vlan Management > Port to Vlan)
Then you tag any Vlans which you want to allow across the trunk.
It literally is as easy at that,
