Voice Vlan on SF300-24P
Roy Jones
I am replacing an 8 port Catalyst 3560 switch with an SF300-24P switch. The 3560 has IP Routing, and has an IP route to send traffic to the Router. It also has Interface Vlan1 and Interface Vlan2, with static IP addresses for each. On the SF300, I cannot seem to get the Vlan2 interface to come up? I tried creating the interface under "IP CONFIGURATION >> IPv4 Interfaces, and shows a valid status. I cannot ping the Vlan2 interface. All devices connect on Vlan1. The phones are not able to connect to the voice vlan, (Vlan2)
Mark Malone
Hey For a vlan to come up there needs to be an access port set as vlan 2 first have you done that bit or just went straight to creating the vlan at layer 3 interface
I don't believe I have. I created the Vlan under Vlan management, even tried to apply vlan 2 with the Port To Vlan tab. All the ports are set to trunk. Where would I set an access port in this gui?
Only have an SG300 to check but if its the same GUI under vlan management under interface settings attached screenshot
Ok, yes the gui is the same. I tried that, but still no change. It seems like this happens sometimes on an IOS switch, but you could use the switchport voice vlan 2 command on the interface, and it would say vlan 2 is not created, would you like to create it. Then it would, and it would just work... I can't get that vlan2 interface to come up for some reason...
