VRRP/HSRP CISCO 3560
O&M MPLS CNT
Hi.
Today I tried to config a HSRP group on a Vlan A and VRRP on a Vlan B, in that order. But, When enter vrrp 30 ip x.x.x.x, it showed me an error telling me that I'm wrong about FHRP group number. This was on a Cisco3560.
To solve this and be able to configure VRRP, I had to delete HSRP config at all from my switch.
Is it normal on that platform? Is there any restriction related?
Francesco Molino
The switch support both protocols but not at the same time :
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/software/release/12-2_58_se/configuration/guide/3560scg/swhsrp.html#47648
See VRRP Limitation chapter.
PS: Please don't forget to rate and mark as correct answer if this solved your issue
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
Hi Supportlan.
Thank you so much. I read restrictions.
You are right.
