Warning %MLDP-W-ABORT: Connection to Unit 2 is aborted due to Stack Management notification.
Michel Zehnder
Beginner
Beginner
We've had a hiccup yesterday.
Is this something that we need to look at closer?
Stack of 2x SG500XG-8F8T, redundant connections.
Michel
1474812372015-Jun-30 20:52:28Informational%AAA-I-CONNECT: New https connection for user <user>, source <ip> destination <ip> ACCEPTED
21474812402015-Jun-30 20:12:56Informational%STCK SYSL-I-UNITTRP: UNIT ID 2,Trap:%Environment-I-FANS-SPEED-CHNG: FAN'S speed level - 0 changed to level - 1.
21474812412015-Jun-30 20:11:03Warning%SNMP-W-SNMPAUTHFAIL: Access attempted by unauthorized NMS
21474812422015-Jun-30 20:08:36Notice%STCK SYSL-N-UNITMSG: UNIT ID 2,Msg:%SYSLOG-N-LOGGING: Logging started.
21474812432015-Jun-30 20:08:34Warning%STP-W-PORTSTATUS: te2/2/12: STP status Forwarding
21474812442015-Jun-30 20:08:32Warning%STP-W-PORTSTATUS: te2/2/10: STP status Forwarding
21474812452015-Jun-30 20:08:31Warning%STP-W-PORTSTATUS: te2/2/9: STP status Forwarding
21474812462015-Jun-30 20:08:31Informational%LINK-I-Up:  te2/2/14
21474812472015-Jun-30 20:08:31Informational%TRUNK-I-PORTADDED: Port te2/2/14 added to Po14
21474812482015-Jun-30 20:08:31Informational%LINK-I-Up:  te2/2/3
21474812492015-Jun-30 20:08:31Informational%TRUNK-I-PORTADDED: Port te2/2/3 added to Po3
21474812502015-Jun-30 20:08:30Informational%LINK-I-Up:  te2/2/2
21474812512015-Jun-30 20:08:30Informational%TRUNK-I-PORTADDED: Port te2/2/2 added to Po2
21474812522015-Jun-30 20:08:30Informational%LINK-I-Up:  te2/2/1
21474812532015-Jun-30 20:08:30Informational%TRUNK-I-PORTADDED: Port te2/2/1 added to Po1
21474812542015-Jun-30 20:08:29Informational%LINK-I-Up:  te2/2/12
21474812552015-Jun-30 20:08:27Informational%LINK-I-Up:  te2/2/10
21474812562015-Jun-30 20:08:26Informational%LINK-I-Up:  te2/2/9
21474812572015-Jun-30 20:08:26Informational%NSFP-I-SFPGibicDetected: te2/2/14 SFP port is present
21474812582015-Jun-30 20:08:25Warning%LINK-W-Down:  gi2/2/1
21474812592015-Jun-30 20:08:24Warning%LINK-W-Down:  te2/2/14
21474812602015-Jun-30 20:08:24Informational%2SWTRUNK-I-TRNKPORTPARAM: auto-negotiation/adv. capabilities of port te2/2/14 differ from auto-negotiation/adv. capabilities of Po14
21474812612015-Jun-30 20:08:21Warning%LINK-W-Down:  te2/2/13
21474812622015-Jun-30 20:08:19Informational%NSFP-I-SFPGibicDetected: te2/2/12 SFP port is present
21474812632015-Jun-30 20:08:19Warning%LINK-W-Down:  te2/2/12
21474812642015-Jun-30 20:08:17Informational%NSFP-I-SFPGibicDetected: te2/2/11 SFP port is present, module type - 1000BASE-CX
21474812652015-Jun-30 20:08:17Warning%LINK-W-Down:  te2/2/11
21474812662015-Jun-30 20:08:15Informational%NSFP-I-SFPGibicDetected: te2/2/10 SFP port is present
21474812672015-Jun-30 20:08:15Warning%LINK-W-Down:  te2/2/10
21474812682015-Jun-30 20:08:15Informational%DSYNCH-I-SYNCH_SUCCEEDED: Synchronization with unit 2 is finished successfully
21474812692015-Jun-30 20:08:13Informational%NSFP-I-SFPGibicDetected: te2/2/9 SFP port is present
21474812702015-Jun-30 20:08:13Warning%LINK-W-Down:  te2/2/9
21474812712015-Jun-30 20:08:10Warning%LINK-W-Down:  te2/2/8
21474812722015-Jun-30 20:08:10Warning%LINK-W-Down:  te2/2/7
21474812732015-Jun-30 20:08:09Warning%LINK-W-Down:  te2/2/6
21474812742015-Jun-30 20:08:09Warning%LINK-W-Down:  te2/2/5
21474812752015-Jun-30 20:08:09Warning%LINK-W-Down:  te2/2/4
21474812762015-Jun-30 20:08:09Warning%LINK-W-Down:  te2/2/3
21474812772015-Jun-30 20:08:09Warning%LINK-W-Down:  te2/2/2
21474812782015-Jun-30 20:08:08Warning%LINK-W-Down:  te2/2/1
21474812792015-Jun-30 20:08:07Informational%Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration change trap., aggregated (1)
21474812802015-Jun-30 20:08:03Informational%STCK SYSL-I-UNITMSG: UNIT ID 2,Msg:%MLDP-I-CONNECT: Connection to Unit 1 is established.
21474812812015-Jun-30 20:08:03Informational%STCK SYSL-I-UNITMSG: UNIT ID 2,Msg:%MLDP-I-SLAVE: Switching to the Slave Mode.
21474812822015-Jun-30 20:08:03Informational%STCK SYSL-I-UNITMSG: UNIT ID 2,Msg:%CSCDLAG-I-ACTIVE: Stack port XG16 is active in stack LAG 1
21474812832015-Jun-30 20:08:03Informational%STCK SYSL-I-UNITMSG: UNIT ID 2,Msg:%CSCDLAG-I-UP: Stack port XG16 operational status is UP
21474812842015-Jun-30 20:08:03Informational%STCK SYSL-I-UNITMSG: UNIT ID 2,Msg:%INIT-I-InitCompleted: Initialization task is completed
21474812852015-Jun-30 20:08:02Informational%MLDP-I-CONNECT: Connection to Unit 2 is established.
21474812862015-Jun-30 20:07:45Informational%CSCDLAG-I-ACTIVE: Stack port XG15 is active in stack LAG 2, aggregated (1)
21474812872015-Jun-30 20:07:45Informational%CSCDLAG-I-UP: Stack port XG15 operational status is UP, aggregated (1)
21474812882015-Jun-30 20:06:43Warning%CSCDLAG-W-DOWN: Stack port XG15 operational status is Down
21474812892015-Jun-30 20:06:38Informational%CSCDLAG-I-ACTIVE: Stack port XG15 is active in stack LAG 2
21474812902015-Jun-30 20:06:38Informational%CSCDLAG-I-UP: Stack port XG15 operational status is UP
21474812912015-Jun-30 20:06:21Informational%Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration change trap.
21474812922015-Jun-30 20:06:21Informational%Stack-I-STCK-BCKUP-REM: Backup master unit 2 was removed from the stack.
21474812932015-Jun-30 20:06:21Warning%LINK-W-Not Present:  gi2/2/1
21474812942015-Jun-30 20:06:21Warning%LINK-W-Not Present:  te2/2/14
21474812952015-Jun-30 20:06:21Warning%LINK-W-Not Present:  te2/2/13
21474812962015-Jun-30 20:06:21Warning%LINK-W-Not Present:  te2/2/12
21474812972015-Jun-30 20:06:21Warning%LINK-W-Not Present:  te2/2/11
21474812982015-Jun-30 20:06:21Warning%LINK-W-Not Present:  te2/2/10
21474812992015-Jun-30 20:06:21Warning%LINK-W-Not Present:  te2/2/9
21474813002015-Jun-30 20:06:21Warning%LINK-W-Not Present:  te2/2/8
21474813012015-Jun-30 20:06:21Warning%LINK-W-Not Present:  te2/2/7
21474813022015-Jun-30 20:06:21Warning%LINK-W-Not Present:  te2/2/6
21474813032015-Jun-30 20:06:21Warning%LINK-W-Not Present:  te2/2/5
21474813042015-Jun-30 20:06:21Warning%LINK-W-Not Present:  te2/2/4
21474813052015-Jun-30 20:06:21Warning%LINK-W-Not Present:  te2/2/3
21474813062015-Jun-30 20:06:21Warning%LINK-W-Not Present:  te2/2/2
21474813072015-Jun-30 20:06:21Warning%LINK-W-Not Present:  te2/2/1
21474813082015-Jun-30 20:06:21Warning%TRUNK-W-PORTDOWN: Port te2/2/14 removed from Po14: port is down/notPresent
21474813092015-Jun-30 20:06:21Warning%TRUNK-W-PORTDOWN: Port te2/2/3 removed from Po3: port is down/notPresent
21474813102015-Jun-30 20:06:21Warning%TRUNK-W-PORTDOWN: Port te2/2/2 removed from Po2: port is down/notPresent
21474813112015-Jun-30 20:06:21Warning%TRUNK-W-PORTDOWN: Port te2/2/1 removed from Po1: port is down/notPresent
21474813122015-Jun-30 20:06:21Warning%MLDP-W-ABORT: Connection to Unit 2 is aborted due to Stack Management notification.
21474813132015-Jun-30 20:06:21Warning%CSCDLAG-W-DOWN: Stack port XG15 operational status is Down
21474813152015-Jun-30 19:51:42Informational%STCK SYSL-I-UNITTRP: UNIT ID 2,Trap:%Environment-I-FANS-SPEED-CHNG: FAN'S speed level - 0 changed to level - 1.
21474813172015-Jun-30 19:45:59Notice%STCK SYSL-N-UNITMSG: UNIT ID 2,Msg:%SYSLOG-N-LOGGING: Logging started.
21474813182015-Jun-30 19:45:56Warning%STP-W-PORTSTATUS: te2/2/12: STP status Forwarding
21474813192015-Jun-30 19:45:55Warning%STP-W-PORTSTATUS: te2/2/10: STP status Forwarding
21474813202015-Jun-30 19:45:54Warning%STP-W-PORTSTATUS: te2/2/9: STP status Forwarding
21474813212015-Jun-30 19:45:54Informational%LINK-I-Up:  te2/2/14
21474813222015-Jun-30 19:45:54Informational%TRUNK-I-PORTADDED: Port te2/2/14 added to Po14
21474813232015-Jun-30 19:45:54Informational%LINK-I-Up:  te2/2/3
21474813242015-Jun-30 19:45:54Informational%TRUNK-I-PORTADDED: Port te2/2/3 added to Po3
21474813252015-Jun-30 19:45:53Informational%LINK-I-Up:  te2/2/2
21474813262015-Jun-30 19:45:53Informational%TRUNK-I-PORTADDED: Port te2/2/2 added to Po2
21474813272015-Jun-30 19:45:53Informational%LINK-I-Up:  te2/2/1
21474813282015-Jun-30 19:45:53Informational%TRUNK-I-PORTADDED: Port te2/2/1 added to Po1
21474813292015-Jun-30 19:45:52Informational%LINK-I-Up:  te2/2/12
21474813302015-Jun-30 19:45:50Informational%LINK-I-Up:  te2/2/10
21474813312015-Jun-30 19:45:49Informational%LINK-I-Up:  te2/2/9
21474813322015-Jun-30 19:45:49Informational%NSFP-I-SFPGibicDetected: te2/2/14 SFP port is present
21474813332015-Jun-30 19:45:47Warning%LINK-W-Down:  gi2/2/1
21474813342015-Jun-30 19:45:47Warning%LINK-W-Down:  te2/2/14
21474813352015-Jun-30 19:45:47Informational%2SWTRUNK-I-TRNKPORTPARAM: auto-negotiation/adv. capabilities of port te2/2/14 differ from auto-negotiation/adv. capabilities of Po14
21474813362015-Jun-30 19:45:44Warning%LINK-W-Down:  te2/2/13
21474813372015-Jun-30 19:45:42Informational%NSFP-I-SFPGibicDetected: te2/2/12 SFP port is present
21474813382015-Jun-30 19:45:42Warning%LINK-W-Down:  te2/2/12
21474813392015-Jun-30 19:45:40Informational%NSFP-I-SFPGibicDetected: te2/2/11 SFP port is present, module type - 1000BASE-CX
21474813402015-Jun-30 19:45:40Warning%LINK-W-Down:  te2/2/11
21474813412015-Jun-30 19:45:38Informational%NSFP-I-SFPGibicDetected: te2/2/10 SFP port is present
21474813422015-Jun-30 19:45:38Warning%LINK-W-Down:  te2/2/10
21474813432015-Jun-30 19:45:38Informational%DSYNCH-I-SYNCH_SUCCEEDED: Synchronization with unit 2 is finished successfully
21474813442015-Jun-30 19:45:36Informational%NSFP-I-SFPGibicDetected: te2/2/9 SFP port is present
21474813452015-Jun-30 19:45:35Warning%LINK-W-Down:  te2/2/9
21474813462015-Jun-30 19:45:33Warning%LINK-W-Down:  te2/2/8
21474813472015-Jun-30 19:45:33Warning%LINK-W-Down:  te2/2/7
21474813482015-Jun-30 19:45:32Warning%LINK-W-Down:  te2/2/6
21474813492015-Jun-30 19:45:32Warning%LINK-W-Down:  te2/2/5
21474813502015-Jun-30 19:45:32Warning%LINK-W-Down:  te2/2/4
21474813512015-Jun-30 19:45:32Warning%LINK-W-Down:  te2/2/3
21474813522015-Jun-30 19:45:31Warning%LINK-W-Down:  te2/2/2
21474813532015-Jun-30 19:45:31Warning%LINK-W-Down:  te2/2/1
21474813542015-Jun-30 19:45:30Informational%Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration change trap., aggregated (1)
21474813552015-Jun-30 19:45:25Informational%STCK SYSL-I-UNITMSG: UNIT ID 2,Msg:%MLDP-I-CONNECT: Connection to Unit 1 is established.
21474813562015-Jun-30 19:45:25Informational%STCK SYSL-I-UNITMSG: UNIT ID 2,Msg:%MLDP-I-SLAVE: Switching to the Slave Mode.
21474813572015-Jun-30 19:45:25Informational%STCK SYSL-I-UNITMSG: UNIT ID 2,Msg:%CSCDLAG-I-ACTIVE: Stack port XG16 is active in stack LAG 1
21474813582015-Jun-30 19:45:25Informational%STCK SYSL-I-UNITMSG: UNIT ID 2,Msg:%CSCDLAG-I-UP: Stack port XG16 operational status is UP
21474813592015-Jun-30 19:45:25Informational%STCK SYSL-I-UNITMSG: UNIT ID 2,Msg:%INIT-I-InitCompleted: Initialization task is completed
21474813602015-Jun-30 19:45:25Informational%MLDP-I-CONNECT: Connection to Unit 2 is established.
21474813612015-Jun-30 19:45:07Informational%CSCDLAG-I-ACTIVE: Stack port XG15 is active in stack LAG 2, aggregated (1)
21474813622015-Jun-30 19:45:07Informational%CSCDLAG-I-UP: Stack port XG15 operational status is UP, aggregated (1)
21474813632015-Jun-30 19:44:06Warning%CSCDLAG-W-DOWN: Stack port XG15 operational status is Down
21474813642015-Jun-30 19:43:58Informational%CSCDLAG-I-ACTIVE: Stack port XG15 is active in stack LAG 2
21474813652015-Jun-30 19:43:58Informational%CSCDLAG-I-UP: Stack port XG15 operational status is UP
21474813662015-Jun-30 19:43:41Informational%Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration change trap.
21474813672015-Jun-30 19:43:41Informational%Stack-I-STCK-BCKUP-REM: Backup master unit 2 was removed from the stack.
21474813682015-Jun-30 19:43:41Warning%LINK-W-Not Present:  gi2/2/1
21474813692015-Jun-30 19:43:41Warning%LINK-W-Not Present:  te2/2/14
21474813702015-Jun-30 19:43:41Warning%LINK-W-Not Present:  te2/2/13
21474813712015-Jun-30 19:43:41Warning%LINK-W-Not Present:  te2/2/12
21474813722015-Jun-30 19:43:41Warning%LINK-W-Not Present:  te2/2/11
21474813732015-Jun-30 19:43:41Warning%LINK-W-Not Present:  te2/2/10
21474813742015-Jun-30 19:43:41Warning%LINK-W-Not Present:  te2/2/9
21474813752015-Jun-30 19:43:41Warning%LINK-W-Not Present:  te2/2/8
21474813762015-Jun-30 19:43:41Warning%LINK-W-Not Present:  te2/2/7
21474813772015-Jun-30 19:43:41Warning%LINK-W-Not Present:  te2/2/6
21474813782015-Jun-30 19:43:40Warning%LINK-W-Not Present:  te2/2/5
21474813792015-Jun-30 19:43:40Warning%LINK-W-Not Present:  te2/2/4
21474813802015-Jun-30 19:43:40Warning%LINK-W-Not Present:  te2/2/3
21474813812015-Jun-30 19:43:40Warning%LINK-W-Not Present:  te2/2/2
21474813822015-Jun-30 19:43:40Warning%LINK-W-Not Present:  te2/2/1
21474813832015-Jun-30 19:43:40Warning%TRUNK-W-PORTDOWN: Port te2/2/14 removed from Po14: port is down/notPresent
21474813842015-Jun-30 19:43:40Warning%TRUNK-W-PORTDOWN: Port te2/2/3 removed from Po3: port is down/notPresent
21474813852015-Jun-30 19:43:40Warning%TRUNK-W-PORTDOWN: Port te2/2/2 removed from Po2: port is down/notPresent
21474813862015-Jun-30 19:43:40Warning%TRUNK-W-PORTDOWN: Port te2/2/1 removed from Po1: port is down/notPresent
21474813872015-Jun-30 19:43:40Warning%MLDP-W-ABORT: Connection to Unit 2 is aborted due to Stack Management notification.
0 Replies 0
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
