12-13-2011 09:42 AM
We had a SGE-2010, just purchased 2 (two) SGE-2010P. I want to stack the switches (all 3) (unless there is a better way). Not sure what is needed hardware wise, and how to physically wire the switches. Had switches years ago (diff brand) that used a special cable that connected the switches. It seems that is not the case here. I have not used fiber in networking before so I am new to that part, I’m willing to learn, just need pointed in the right direction.
Details:
The switches will all be in one rack.
Currently we use 100/1000Base-T to all the computers / servers.
Currently 1 switch (2 nd one just died) is connected to the SGE-2010 (LAG over two ports)
Currently 5 servers are connected to the SGE-2010 (LAG over two ports each).
A bunch of individual computers where thrown onto the SGE-2010 when the other switch died.
All the servers and computers are on 1 big happy LAN, all the computers need to access all the servers. No need to separate things.
Side Note:
Will be moving to new building in about a year. MIGHT have VOIP, so I might need to add another switch or two.
Questions:
Can all three switches be stacked, (1) SGE-2010 & (2) SGE-2010P?
I THINK I need to use the GBIC port 4 to stack, I understand 1 port is enough if two switches are used, but what about three or more switches.
What are the other GBIC ports used for?
Will I be better off (can I ) use the GBIC ports LAG (2 ports) to the other switches? Or would regular ports work just as well?
Thanks for you help
Solved! Go to Solution.
12-14-2011 11:28 AM
Hi Ric,
Thank you for posting. Please see the following diagram that demonstrates how to stack 3 switches:
12-14-2011 01:14 PM
Ric,
Using the regular ports should give the same performance. As far as I know you can stack the SGE2010P with the SGE2010 without issue.
12-13-2011 11:07 AM
Ric,
Look over the admin guide and repost further questions:
Page 20
Jasbryan
12-14-2011 08:46 AM
Jasbryan, thanks for the link. I have read most of Chapter 2 in the Administration guide before I posted here. I re-read page 20 (also page 19&21 just in case). I must be brain dead I don't see anywhere on page #20, or the rest of the chapter, pertaining to my questions.
12-14-2011 11:28 AM
Hi Ric,
12-14-2011 12:44 PM
Mpyhala, thanks for the diagram. I take it that I do NOT have to use the GBIC ports? Glanced back over the Admin Guide, did not see where it said I HAD to use the GBIC ports, but I have it in my head that I do have to use them to stack for some reason.
Will using the regular ports 24 & 48 give the same performance as using GBIC port 3 & 4?
Have not heard anyone complain about mixing SGE2010 & SGE2010P in one stack so I’m going to say it is OK. Personally I do not see why not, other than watching where I plug in an item that needs power.
12-14-2011 01:14 PM
Ric,
12-14-2011 03:02 PM
Ric,
Usually customer use the mini-gbic modules for switches that have distance of 300' + between each other.
The end copper ports are shared with two mini-gbic ports that also can be used with the stack mode.
Jasbryan
