06-11-2016 08:28 AM - edited 03-08-2019 06:09 AM
السلام عليكم
اني طالب ادرس حاليا ccnax 200-120
عندي سويج سيسكو اتدرب عليه c3550
switch:
راح السوفت وير و طلع عندي فقط
switch:
switch: ?
? -- Present list of available commands
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
flash_init -- Initialize flash filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
load_helper -- Load and initialize a helper image
memory -- Present memory heap utilization information
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
rename -- Rename a file
reset -- Reset the system
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
set_param -- Set system parameters in flash
sleep -- Pause (sleep) for a specified number of seconds
trap -- Cause a software breakpoint to occur
-- MORE --
type -- Concatenate (type) file(s)
unset -- Unset one or more environment variables
version -- Display boot loader version
switch:
ارجو الرد
06-12-2016 01:12 AM
Use this document to solve your problem.
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/41845-192.html
Follow the steps and your problem should be finished.
06-26-2023 06:24 PM
وعليكم السلام
