Error when two HWIC-4ESW modules are installed on the Cisco 2911/K9
Translator
Community Manager
Community Manager
Hello
I was using one HWIC-4ESW module on Cisco 2911/K9.
But I didn't have enough ports, so I added HWIC-4ESW.
And HWIC-4ESW showed abnormal movement.
Both Interface and protocol came up, but the ping was not performed.
What I checked was;
1. The ping went well when I connected it to the HWIC-4ESW that I added.
2. I removed the HWIC-4ESW that I added, and the existing HWIC-4ESW ping went well.
Can't I use two HWIC-4ESWs on the Cisco 2911/K9?
Thanks.
5 Replies 5
marce1000
             >...And HWIC-4ESW showed abnormal movement.
                  - What is the error you are getting ?
 M.
as far as I recall (and I might be wrong, as these are rather old devices) two of the HWIC-4ESW do work, but there is no backplane connecting them, so you have to connect both modules with a (crossover) cable.
Translator
Community Manager
Community Manager
Hello
Error messages are not checked when installing HWIC-4ESW.
When I check show interface fa0/3/0, it all looks normal.
However, there is no icmp communication with other routers connected to interface fa0/3/0.
The ip setting is normal.
Translator
Community Manager
Community Manager
I'm not sure what you mean.
I'm going to leave the part in question as a picture.
Translator
Community Manager
Community Manager
Hi, @Georg Pauwen
Is it right to set the information you told me as below?
