09-08-2017 11:13 PM - edited 03-08-2019 11:58 AM
We have recently made some changes and have a 10G port channel between a 4500 to 3850. The channel bonds as it should. The issue is an cctv cameras the are on edge switches connected to the 3850 start to pixilate, freeze and generally have issues once the channel bonds. Once the the channel is taken back to a single link the cctv cameras return to normal. We have other 1G etherchannels connected to the 4500 core switch that do not have this error.
The cameras are all running H.264 codec.
I'd be greatful if somone could point me in a direction to start troubleshooting this one.
Solved! Go to Solution.
09-09-2017 02:25 PM - edited 09-09-2017 02:28 PM
Are you completelly sure you don't have layer 1 issue?
I'd recommend you to read this:
09-09-2017 10:13 PM
thanks mate spot on
