01-27-2012 08:31 AM - edited 03-07-2019 04:35 AM
Looking to link up to 6513 chassis via 6704 10 gig cards.
I have a 6513 on the 8th floor and one on the 3rd floor in same building. Distance would be approx 150' max.
New 10 gig cabling was installed between these floors.
I would like to use 2 10 gig ints on each 6704 to form a port channel (LACP) between the 2 environments.
So far I have been unable to get the links up between 6704's.
Is this a distance issue ?
Cheers
Dave
01-27-2012 08:44 AM
Looks like my issue is I am using xenpak-10gig-SR optics...
01-27-2012 10:21 AM
Problem solved !!
I have 15 pair of 10 gig patches between floors and the 1st 2 I tried for this uplink didnt work..But it turns out to be a problem with the
interconnects on the patch panel as the 3rd uplink I tried works fine
trunk is up and running now
First one being bad I can understand, but 2 being bad...well I didnt think it could be that..But you never know.
Cheers
Dave
