10 gig gbic for cisco switches
David Hunt
Hello friends,
I am trying to establish a 10 GB fiber connection between two Cisco switches.
Switch 1 - Cisco WS-C3650-48PQ has 4 x 10 Gigabit Ethernet with SFP+ uplinks
Switch 2 - Cisco WS-C2960X-48FPD-L has 2 x 10 Gigibit Ethernet with SFP+ uplinks
Currently between the 2 switches I have an active 1 GB multi mode fiber connection with both switches using Cisco GBIC 1000BASE-SX.
I am trying to upgrade the link to 10 GB, prior to purchase I selected Cisco SFP-10G-SR from the Cisco data sheet
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c78-455693.html
while I am able to get connectivity over 1 GB I am unable to get connectivity over 10 GB. I get no lights, nothing.
Any ideas what I might be missing? Did i purchase the wrong Gbics?
any info is greatly appreciated.
11 Replies 11
Leo Laohoo
What kind of fibre optic cable are you using? Single or multi-mode?
What is the distance between the two appliances?
Thank you for your quick response, I am using the aqua blue colored MM cable
What is the distance?
3 meters . However when deployed maybe 100 meters
Post the complete output to the command "sh inventory"and "sh version" from both switches.
Cisco 3650
Show inventory
NAME: "c36xx Stack", DESCR: "c36xx Stack"
PID: WS-C3650-48PQ , VID: V03 , SN: FDO2005Q0LC
NAME: "Switch 1", DESCR: "WS-C3650-48PQ"
NAME: "Switch 1 - Power Supply A", DESCR: "Switch 1 - Power Supply A"
PID: PWR-C2-1025WAC , VID: V02 , SN: DCB1951C8F1
NAME: "TenGigabitEthernet1/1/1", DESCR: "SFP-10GBase-LR"
PID: SFP-10G-LR , VID: V02 , SN: SPC182104BG
NAME: "Switch 2", DESCR: "WS-C3650-48PQ"
PID: WS-C3650-48PQ , VID: V03 , SN: FDO2005E1G9
NAME: "Switch 2 - Power Supply A", DESCR: "Switch 2 - Power Supply A"
PID: PWR-C2-1025WAC , VID: V02 , SN: DCB1951C8F5
NAME: "TenGigabitEthernet2/1/1", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MM-RGD , VID: V02 , SN: FNS20090NDX
NAME: "TenGigabitEthernet2/1/4", DESCR: "SFP-10GBase-SR"
PID: SFP-10G-SR , VID: V03 , SN: AVD21209E87
Show version
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.06.04.E RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Sat 13-Feb-16 03:45 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 1.18, RELEASE SOFTWARE (P)
WLC-Switch-100.10 uptime is 22 weeks, 4 days, 2 hours, 41 minutes
Uptime for this control processor is 22 weeks, 4 days, 2 hours, 45 minutes
System returned to ROM by reload
System image file is "flash:packages.conf"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: Lanbase
License Type: Permanent
Next reload license Level: Lanbase
cisco WS-C3650-48PQ (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FDO2005Q0LC
1 Virtual Ethernet interface
96 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
252000K bytes of Crash Files at crashinfo:.
250456K bytes of Crash Files at crashinfo-2:.
1611414K bytes of Flash at flash:.
1609272K bytes of Flash at flash-2:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of Dummy USB Flash at usbflash0-2:.
0K bytes of at webui:.
Base Ethernet MAC Address : 00:c1:64:e3:fe:00
Motherboard Assembly Number : 73-15903-04
Motherboard Serial Number : FDO2005104C
Model Revision Number : K0
Motherboard Revision Number : B0
Model Number : WS-C3650-48PQ
System Serial Number : FDO2005Q0LC
Switch Ports Model SW Version SW Image Mode
* 1 52 WS-C3650-48PQ 03.06.04.E cat3k_caa-universalk9 INSTALL
2 52 WS-C3650-48PQ 03.06.04.E cat3k_caa-universalk9 INSTALL
Switch 02
Switch uptime : 22 weeks, 4 days, 2 hours, 46 minutes
Base Ethernet MAC Address : 00:c1:64:ee:e4:80
Motherboard Serial Number : FDO2005100P
System Serial Number : FDO2005E1G9
Configuration register is 0x102
Cisco 2960
show inventory
NAME: "1", DESCR: "WS-C2960X-48FPD-L"
PID: WS-C2960X-48FPD-L , VID: V07 , SN: FCW2130B2GV
NAME: "TenGigabitEthernet1/0/1", DESCR: "SFP-10GBase-SR"
PID: SFP-10G-SR , VID: V03 , SN: AVD21209EDR
NAME: "GigabitEthernet1/0/50", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MM-RGD , VID: V02 , SN: FNS20090P44
show version
WLC-SKATE-100.17#show ver
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E6, RELEASE SOFTWARE (fc1)
Compiled Fri 16-Dec-16 21:27 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.2(3r)E1, RELEASE SOFTWARE (fc1)
WLC-SKATE-100.17 uptime is 4 hours, 48 minutes
System restarted at 10:26:45 UTC Thu Oct 26 2017
System image file is "flash:/c2960x-universalk9-mz.152-2.E6/c2960x-universalk9-mz.152-2.E6.bin"
export@cisco.com.
cisco WS-C2960X-48FPD-L (APM86XXX) processor (revision U0) with 524288K bytes of memory.
Processor board ID FCW2130B2GV
Last reset from power-on
1 FastEthernet interface
50 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 74:86:0B:01:E3:80
Motherboard assembly number : 73-16686-06
Power supply part number : 341-0527-03
Motherboard serial number : FOC21276EMG
Power supply serial number : DCB21246457
Model revision number : U0
Motherboard revision number : C0
Model number : WS-C2960X-48FPD-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FOC21298NML
System serial number : FCW2130B2GV
Top Assembly Part Number : 68-100463-03
Top Assembly Revision Number : B0
Version ID : V07
CLEI Code Number : CMMLJ00ARG
Daughterboard revision number : B0
Hardware Board Revision Number : 0x19
* 1 52 WS-C2960X-48FPD-L 15.2(2)E6 C2960X-UNIVERSALK9-M
Configuration register is 0xF
On the 3650, can you try adding the command "speed nonegotiate"?
I thought about that but with no light received indicates to me no connection at all. The only time I get a connection or "light" is when using the 1000BaseSX SFP. When I insert the SFP-10GBase-SR GBIC and swap patch cables, I do not receive any light or connection.
The theory I am working with is...
* I am using the wrong GBIC
o However, in examining the datasheets for both 1000BaseSX SFP and SFP-10GBase-SR. I am fairly confident I am selected the proper GBIC
? https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/gigabit-ethernet-gbic-sfp-modules/product_data_sheet0900aecd8033f885.html
? https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c78-455693.html
* IOS is not current enough or not compatible
o In examining the IOS transceiver compatibility matrix - https://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html#_Toc496618965
? WS-C2960X-48FPD-L- requires a min IP of 15.0(2)EX
* I am running model WS-C2960X-48FPD-L SW Version 15.2(2)E6 SW Image C2960X-UNIVERSALK9-M
? WS-C3650-48PQ - requires a min IOS of XE 3.3.0SE
* I am running model WS-C3650-48PQ SW Version 03.06.04.E SW Image cat3k_caa-universalk9
With regards to the WS-C2960X-48FPD-L , I know nothing of the subtle differences between Version 15.0(2) EX verse Version 15.2(2)E6, or breaking it down further EX verse E6, could this minor difference be the issue?
With regards to the WS-C3650-48PQ , SW Version 03.06.04.E verse XE 3.3.0SE, I think I am fine, but again, subtle differences.
I don't think it is anything physical, meaning patch cable, fiber type, distance mainly because it works using 1000BaseSX SFP
You're not working on a wrong part.  I've thought about this and this is why I asked for the "sh inventory" output.
I'll be frank with you, I suspect the problem is on the 3560.  Can you upgrade the IOS to something NEWER (but stay with 3.6.X)?
which releases are you running on both switches ?  On the Cisco WS-C2960X-48FPD-L, you need at least 15.0(2)EX, and on the Cisco WS-C3650-48PQ, you need at least XE 3.3.0SE.
Check this link for reference:
Cisco 10-Gigabit Ethernet Transceiver Modules Compatibility Matrix
Reza Sharifi
Is this a back-to-back connection or through patch panels? Have you tested the fiber patch?
You may want to cross the fiber stands on ONE side on the connection and test again.
