1000Base-T GLC-T connected to an SFP+ interface in a 4500X running 03.07.02.E not working
d3m.system
We have a 100Base-T GLC-T gbic connected to a TenGig interface of a 4500x switch, but when we try to connect a device to that port i.e: either a server or another switch like a 3850, the port does not come up at 1Gb on the 4500X:
Te1/1/8                      notconnect   routed       full   auto 1000BaseT
CASE1:
Switch 4500X, interface TenGiga 1/1/8 using GLC-T Gbic connected to a Catalyst 3850 switch on GigaEthernet 1/0/1, both interfaces set to auto negotiate
On 4500X
Port      Name               Status       Vlan       Duplex  Speed Type
On 3850
Gi1/0/1                      connected    routed     a-full a-1000 10/100/1000BaseTX
CASE2:
Switch 4500X, interface TenGiga 1/1/8 using GLC-T Gbic connected to a Catalyst 3850 switch on GigaEthernet 1/0/1, but both interfaces set manually to 100Mb full duplex:
On 4500X
Te1/1/8                      connected    routed       full    100 1000BaseT
On 3850
Gi1/0/1                      connected    routed       full    100 10/100/1000BaseTX
SW-CORE-M1#show version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch  Software (cat4500e-UNIVERSALK9-M), Version 03.07.02.E RELEASE SOFTWARE (fc1)
ROM: 15.0(1r)SG11
SW-CORE-M1 uptime is 4 hours, 30 minutes
Uptime for this control processor is 4 hours, 32 minutes
System returned to ROM by reload
Running default software
Jawa Revision 2, Winter Revision 0x0.0x41
Last reload reason: Reload Shelf CLI
License Information for 'WS-C4500X-16'
    License Level: entservices   Type: Permanent Right-To-Use
    Next reboot license Level: entservices
the inventory shows:
NAME: "TenGigabitEthernet1/1/8", DESCR: "1000BaseT"
PID: Unspecified       , VID:      , SN: 00000MTC16460019
Unfortunatelly in this version of IOS is not possible to set the speed manually to 1000 I know that since XE 3.7.1E it is possible to set the speed to 10 or 100 manually but I can't see an option to force speed to 1000
Any ideas?
Thanks in advance.
17 Replies 17
d3m.system
We also tried the service unsupported-transceiver command without luck
The Cat4500X only supports 1000/10000 on the port, so auto-negotiation probably won't work.  Your GLC-T will be locked at 1000/Full.
On the 3850, how about:
speed 1000
duplex full
If that doesn't work, disable auto crossover on the 3850 and use a crossover cable.
no mdix auto
(I just installed about sixty 4500Xs and didn't have a single problem with 1Gbps connections.  Difference here is that I was using all fiber, no GLC-T modules.)
Good Luck!
PSC
Hi Paul,
Thanks for your reply.
Since version XE 3.7.1E it is possible to force a SFP+ that has a GLC-T attached to 100Mbps or 10Mbps in a Catalyst 4500X:
SW-CORE-M1(config-if)#speed ?
  10   Force 10 Mbps operation
  100  Force 100 Mbps operation
I was able to stablish a link with a 100Mps device by forcing the speed and the duplex in both ends.
The problem I'm having is that the GLC-T is not working at 1000Mbps, even if I force the other end to be 1000Mpbs full-duplex.
The strange this in that  after reseting interfaces to defaults in both ends the 3850 interface appears as connected and the 4500x interface appears as not connect, this is also reflected in the state of the front panel status LEDs
SW-CORE-M1#show run inter tenGigabitEthernet 1/1/8
Building configuration...
Current configuration : 41 bytes
interface TenGigabitEthernet1/1/8
end
SW-CORE-M1#show inter tenGigabitEthernet 1/1/8
TenGigabitEthernet1/1/8 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet Port, address is 0462.7399.5287 (bia 0462.7399.5287)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, Auto-speed, link type is force-up, media type is 1000BaseT
  input flow-control is off, output flow-control is off
  Last input 00:10:48, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     6842 packets input, 836051 bytes, 0 no buffer
     Received 1915 broadcasts (980 multicasts)
     1306 packets output, 570024 bytes, 0 underruns
     0 output errors, 0 collisions, 9 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
SW-SERVER-M1#show run interface gigabitEthernet 1/0/2
Current configuration : 38 bytes
interface GigabitEthernet1/0/2
end
SW-SERVER-M1#show interfaces gigabitEthernet 1/0/2
GigabitEthernet1/0/2 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0c11.67d3.0c02 (bia 0c11.67d3.0c02)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Half-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:12:19, output never, output hang never
     1031 packets input, 435643 bytes, 0 no buffer
     Received 1024 broadcasts (1021 multicasts)
     0 watchdog, 1021 multicast, 0 pause input
     12702 packets output, 1255459 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     11 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
And btw, we tried the setting about auto crossover but it didn't help
no mdix auto
I hope that makes sense,
Thanks again.
PD: We also tried GLC-LH-SM and GLC-SX-MM and we didn't have any problem with those, they work correctly at 1000Mpbs without any further configuration. Unfortunately we have a couple of devices which need to be connected with RJ45 copper interfaces at 1G, i.e: ASA 5510
Hi -
A couple of thoughts here...
  1. Do a "show interface teX/Y capabilities" and post.  I just did it on one of my deployed 4500X switches and see port speeds of 10/100/1000/10000
  2. Do you get any log messages on the 4500X when the module is plugged in / unplugged / network is connected?
  3. Have you swapped the GLC-T with another one? (I'm guessing you have, but just making sure)
  4. Have you installed a GLC-T in your 3850 and cross connected it to itself? (STP should protect the network; this validates whether the GLC-T works at all.)
PSC
Hi Paul,
1. Capabilities
SW-CORE-M1#show interfaces tenGigabitEthernet 1/1/8 capabilities
Model: WS-C4500X-16-Gbic
Type: 1000BaseT
Speed: 10,100,1000,10000
Duplex: full
Auto-MDIX: no
EEE: no
Trunk encap. type: 802.1Q
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: percentage(0-100), hw
Multicast suppression: percentage(0-100), hw
Flowcontrol: rx-(off,on,desired),tx-(off,on,desired)
VLAN Membership: static, dynamic
Fast Start: yes
CoS rewrite: yes
ToS rewrite: yes
Inline power: no
SPAN: source/destination
UDLD: yes
Link Debounce: yes
Link Debounce Time: yes
Port Security: yes
Dot1x: yes
Maximum MTU: 9198 bytes (Jumbo Frames)
Multiple Media Types: no
Diagnostic Monitoring: N/A
2. When the module is inserted/removed I get a "transciever has been inserted" message, but when I connect a cable to it I don't see anything in the logs.
3. Yes, indeed I did that, but the results are the same with either.
4. No, I haven't done that test, but I'm certain the modules work, both of them were in production, they were previously installed in a Catalyst 3750 and were operating correctly
I have a TACs, but I'm still waiting for an answer.
Thanks for your help.
Hi -
I think a TAC case is appropriate.  Here are some outputs from one of the switches we have deployed in the field...
4500X-Switch#sh int te1/3 status
Te1/3 connected trunk full a-1000 1000BaseT
4500X-Switch#sh inv
NAME: "TenGigabitEthernet1/3", DESCR: "1000BaseT"
PID: Unspecified , VID: , SN: <removed>
TenGigabitEthernet1/3 is up, line protocol is up (connected)
<truncated>
<truncated>
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseT
<truncated>
4500X-Switch#sh int te1/3 capabilities
Type: 1000BaseT
Speed: 1000,10000
Duplex: full
Auto-MDIX: no
EEE: no
Channel: yes
Fast Start: yes
CoS rewrite: yes
ToS rewrite: yes
Inline power: no
UDLD: yes
Link Debounce: yes
Port Security: yes
Dot1x: yes
4500X-Switch#sh ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.06.03.E RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 26-Aug-15 06:05 by prod_rel_team
<truncated>
ROM: 15.0(1r)SG11
<truncated>
System image file is "bootflash:cat4500e-universalk9.SPA.03.06.03.E.152-2.E3.bin"
<truncated>
cisco WS-C4500X-16 (MPC8572) processor (revision 9) with 4194304K bytes of physical memory.
Processor board ID <removed>
MPC8572 CPU at 1.5GHz, Cisco Catalyst 4500X
Last reset from PowerUp
34 Virtual Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Two interesting items came out of this check.  1) You can't run the "show interface transceiver" command on interfaces with the GLC-Ts, and 2) Interfaces with GLC-Ts show a capability of 1000/10000.
Good Luck!
PSC
Thanks for your reply Paul
The only notioceable difference between your setup and ours is the version of IOS XE [that's why your tranciever does not appear to be 100Mpbs capable], unfortunately I cannot downgrade, we need the GLC-T gbics to work both at 100Mpbs and 1000Mpbs, unfortunately 3.6 does not support 100Mpbs at all, and we are giving priority to 100Mpbs interfaces as one of our ISP uses and old device only capable of 100Mbps.
Hi -
At this point I'm going to go back to my original answer.  I don't think that the 4500X supports 10/100 connectivity at the ASIC level.  Even the spec sheet (4500-X DataSheet) only shows support for 1Gb and 10Gb SFP modules.  It would seem to me to be a code anomaly when it shows that the port is capable of 10/100 speeds and not just 1000/10000.
Your original query was for 1Gb connectivity from the 4500-X to a server or a Catalyst 3850.  If you are having problems with 1Gb speeds, then I agree with the oddity of the issue.  Since you are now mentioning ISP handoffs at sub-1Gb speeds, then I'm going to stick with the spec sheet.
PSC
As I mentioned before it's not a code anomaly when it shows the port is capable of 10/100, it's a feature introduced in IOS XE 3.7.xE, but I guess you are right, it might be something implemented at software level and not at ASIC level.
I'm still waiting for a proper answer from my TACs case. Yesterday we had a WebEx session and the engineer could not understand why it was not working properly at 1Gps but it working fine at 100Mpbs. They said they will investigate the case. I'll post any updates on that
Thanks.
got the same problem as you mentioned.
I've tried almost every firmware version available.
Did TAC solve the problem and can you share it?
Thanks!
Unfortunatelly no, we could not fix the issue completely .
At the moment we are using the Gbics at 1Gbps only using this release:
Version 03.06.04.E RELEASE SOFTWARE (fc2)
I had to get rid of the old 100Mbps connections and replace those devices with 1Gbps
Something to notice though is that I'm using an apparently very old hardware revision of the Gbics. I have to get a newer model and see if the autonegotiation works in 03.07.XX or 03.08.XX
I hope this helps
Ran into the same issue today on 03.09.00.E.152-5.E.
Can also confirm that 03.06.05.E.152-2.E5 works at 1Gbps.
Hey Paul,
Thanks for the feedback/info.
I'm also using IOS-XE - 03.09.00.E.152-5.E. (out of the box)
and can confirm I'm also seeing exactly the same issue.
Strange how the link comes up on the remote device, but not on the 4500X
Hey,
We are also seeing the same problem.
We are using WS-C4500X-16 with code 03.09.00.E.
Has anybody managed to resolve this? We have tried both GLC-T and GLC-TE
