100gb DAC cable between 40G devices ?
from88
Level 4
Level 4
Could someone assure me that I can use this type of DAC cable: QSFP-100G-CU1M for establishing a 40G connection ? Thanks
5 Replies 5
Reza Sharifi
For what type of switches?
Actually its between Nexus 6k and NCS 5501-SE.
And what is the distance between the 2 devices?
If it is between 2 40G devices, I would use the 40Gig DAC cable.
https://www.fs.com/products/39663.html
1m (3ft) HW QSFP-40G-CU1M Compatible 40G QSFP+ Passive Direct Attach Copper Cable
thanks, it seems that the main question is if the mentioned CISCO 100G QSFP28 cables supports running in QSFP+ mode. Seems like some supports (as it already working in Some 9k Nexuses in 40G mode).
